Hamlet build on perfboard
Started by koky, December 21, 2013, 08:06:52 PM
koky
Couple more question. Can I wire this pedal with standard MB wiring diagram (for true bypass) and is there a way to make status LED blink with repeats?
Happy New Year
"When you want something in life, you just gotta reach out and grab it." - Christopher McCandless
Quote from: koky on January 01, 2014, 09:45:04 AM
Happy New Year
To get an LED to blink in time with the PT2399, you need something that can convert a clock signal into a control voltage.
http://www.diystompboxes.com/smfforum/index.php?topic=102660.0
or you can add Tap Tempo with the Taptation, which has its own LED drivers.
For true bypass, yes, you can use the MB standard wiring diagram instead of the DPDT footswitch wiring in the build document, but you must jumper the connection to the delay line.
