Zero Point
Started by pickdropper, December 26, 2013, 07:29:59 AM
After building for other folks, it was finally time to do one for myself.  I've been wanting to box up my Zero Point Deluxe for quite a while now and I never found the time to do it.  When I finally sat down, I couldn't really decide on the artwork I wanted.  After a bit of fiddling, I came up with this and am pleased with the results.
I like this shot for showing off the texture of the etch.
Very clean indeed for the amount of stuff!
What switching scheme is it?
Quote from: alanp on December 26, 2013, 07:33:34 AM
Thanks, there was indeed a lot to stuff in there.
It's a relay switching scheme based on a board I laid out with the programming done by one of the function f(x) dudes who isn't known on the forums.  I actually mounted the board under the primary PCB.  With all of that, it took a bit of planning, but it went it clean.
Cortexturizer
you call that clean? what an understatement..
Stomptown
Amazing Dave! Laser etched right? How did you do the white lettering?
Quote from: Stomptown on December 26, 2013, 09:34:17 AM
Yep, laser etched.  The white was carefully back filled with a paint pen.  I kept it out of the other etched areas and then scraped the surface.
billstein
One of my favorites that you've done. Pure awesomeness.
Proprietary relay switching system, ha ha ha. Worth starting an effects company just to say those words.
Ettore_M
Awe-some!  8)
Great graphic and I love how you colored the letters white!  ;)
Clean as always!
Hector
- Culturejam
hoodoo
Originality plus, i don't think i've seen another like it, awesome as always. I've said it before and i'll say it again, Man, i wish i had a laser engraver  ;)
Quote from: madbean on December 26, 2013, 12:34:04 PM
Pedal Companies have been built on a lot less.
I saw one the other day where the person announced the pedal company before they had built their first pedal.
Damn, dude. I didn't even realize this was an etch until I saw that detail shot. Great build.
