A thankyou to Hexjibber
Started by fendman, January 08, 2014, 07:47:03 PM
fendman
Seeing some of the etches that Graham has done in the past few months and reading the simple to follow instructions he provides, I thought I would have a go....I have tried etching enclosures in the past. But, never got the results that I was anywhere near happy with.
Well I used the base from my Zero Point delay machine as it has been removed for the last six months...basically for trimming/ tweaking/ changing components in the skts etc.
Went through the tutorial ending with spraying the etch with matt black paint and the following day rubbing it down, and this morning spraying it with a few coats of laquer.
Well,  for a first attempt I was more than happy with the results, its not that difficult and I would recommend anyone to try Grahams' technique.
Thanks
Mike
Hexjibber
http://diy-guitar-effects.tumblr.com/etching
spaceboss
DutchMF
That looks f*&%$n amazing, so cool!
Paul
just wow... wow. Crazy clean etch.
rullywowr
billstein
Thank you for providing that link on how to etch. Does anybody know if caustic soda and lye the same thing?
fendman
Thanks guys for the kind comments.
Quote from: billstein on January 08, 2014, 11:21:56 PM
noun: lye
1.
a strongly alkaline solution, esp. of potassium hydroxide, used for washing or cleansing.
blackedition
This looks excellent!  One of my major hangups with trying etching is that I was worried about the safe disposal of the reacted solution.  It seems like the use of NaOH allows for safe disposal through the drain.  However, I'm super paranoid so...  Can anyone confirm that it is safe to dispose of the used NaOH etchant into the drain?  Thanks!
Also, I noticed that the link in the tutorial for the glossy photo paper used in the process is no longer carried by Amazon.  Did you find a suitable substitute paper?
Great job!
fendman
Quote from: blackedition on January 09, 2014, 12:10:52 PM
Great job!
1
Hi, Like all chemical products if used sensibly and you adhere to the instructions...Sodium Hydroxide can be used in diluted form to clean drains...so its no problem. The only addition to that would be if you had a septic tank... that is you are not connected to mains sewage/sewrage...it might be advisable to ask the relevent authority.
2
I use the backing paper you get on labels, it does vary and can be a bit hit and miss.
blackedition
Quote from: fendman on January 09, 2014, 08:32:59 PM
Great job!
1
2
could you possibly provide a link to the label paper?  i'm sure i'll have to try a few things out for myself to see what gives me the best results, but the link will help provide a good starting point!  thanks!
rullywowr
#11
It's the "backing" you normally throw away when you peel off a self adhesive sticker.  This can work, but sometimes the toner doesn't stick very well to it and it flakes off.  The blue toner transfer paper is really great but expensive. I just picked il some yellow toner transfer paper from eBay and it works great.
