Grapevine Question - Rock/Rawk Switch
Started by FuzzMonkey, March 09, 2011, 07:44:21 AM
FuzzMonkey
I'm currently working on a Grapevine build and have a question regarding the Rock/Rawk switch. Below is an image of the how to wire the DPDT switch, the question I pose is what switch position is what? With the switch in position A or position B if looking at the switch from behind. I'd be grateful for any help on this one.  :-[
bigmufffuzzwizz
If you turned the pedal over so you were looking at the top which you stomp the switch, up would be position A and down would be position B.
Not quite sure exactly what your asking though.
FuzzMonkey
Quote from: bigmufffuzzwizz on March 09, 2011, 08:08:53 AM
Sorry for the confusion, I'm trying to find out if the switch is in the top position i.e. A is the effect in Rock or Rawk mode.
Tpetty5
Going from memory I think A is Rawk and B is Rock.  You will know when you wire it up.  Big difference in the two positions.
FuzzMonkey
Quote from: Tpetty5 on March 09, 2011, 05:29:45 PM
Thanks.
