PS-1A 2 / A1-SP
Started by juansolo, January 30, 2014, 08:14:08 PM
Another couple of Maestro PS-1A clones. However there have been some updates, so I thought I'd post these up where I normally wouldnt.
Layout by JDub on DIYSB, etched by Haberdasher. The HA17458 opamps we got from Tayda work, which is good as other things we tried didn't. It's worth adding the 5 RF surpressing caps underneath the board also as it's good at picking up radio without them.
We've now sorted the power. We're using the following supply and it's perfect for the job (it's hidden under the board and the regulator is bolted to the back of the case).
Another problem we had was that since we were running the effect true bypass, we were getting a pop on stomping the effect. That was traced to there being DC on the output. We replaced the resistor on the output with a 220nF cap, then ran a 1M resistor to ground after it, curing that problem.
The last issue was a bit of a volume drop when engagaed. We've replaced the 2n5087 on the input with a much higher gain BC559C. We think that's what's sorted it, it certainly seems far less noticeable now.
With all these changes and with some more setup, the effect it much better all round. To the point we could actually do with recording a new sound clip for it.
Droogie
Beautiful build, as always! How's it compare to the Stage Fright? Also curious about the box size—looks smaller than a DD but larger than a BB—and it ain't a 1790???
Jabulani Jonny
Dude, this just looks awesome.  Your artwork always kills.  BTW, what font do you use?
Jonathan
billstein
#3
All your builds are beautiful but I think this is my favorite so far.
Quote from: Jabulani Jonny on January 31, 2014, 02:51:55 AM
Feast of Flesh BB which appears to be becoming my main used font (and believe me, I have hundreds of the bloody things). It just works so well with so many things that I keep coming back to it.
muddyfox
Is that a color waterslide under the 'tex? If so, what kind is it?
So...
Is the "backwards etching" going to become a typical Juansolo thing?  ;D
Is there a purpose behind etching the layouts backwards?
Beautiful pedals inside and out though...  ;)
It was fantastic before and it's fantastic again.  One of my favorites.
micromegas
I think we have a thing in this forum for phase shifters...
Beautiful build in and out.
The PS-1A was the first guitar effect that got my attention, all thanks to this song:
(I've been listening to Pink Floyd since I were a newborn and Gilmour is one of my all time favourite guitarists, but this Led Zeppelin song was the first that made me stop and wonder "what kind of effect makes you sound like this")
Software Developer @ bela.io
micromegas
I took a look at the MCA05D12D datasheet and it says that, with a 5v input the max current rating is 42 mA. What are the advantages of using it against a TC1044 Juan (it is quite an expensive chip...)?
Quote from: Govmnt_Lacky on January 31, 2014, 01:39:58 PM
So...
Better ask Haberdasher about that ;)
Quote from: micromegas on January 31, 2014, 02:57:40 PM
The main advantage is that the brick worked. We were getting massive voltage drop we used a TC based inverter with this circuit. Here they're not much difference in price.
Haberdasher
Quote from: juansolo on January 31, 2014, 04:59:05 PM
So...
juan & cleggy have become so adept with all this stuff, i figured they needed the extra challenge of working in "mirror mode".  that's the new "genius level". ;)
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
micromegas
Quote from: juansolo on January 31, 2014, 05:02:37 PM
Got fooled by this: http://www.amazon.co.uk/DC-Converter-1W-Dual/dp/B0084ZM0IS and some ebay prices...
But Farnell's price is cheaper.. half cheaper...
marauder
Quote from: Haberdasher on January 31, 2014, 05:05:25 PM
A genius wouldn't have reversed all the transistors, and then had to put them back in the right way.  It's only mirror horizontally.
