Harbinger One LDR source, advice
Started by luckylulujoe13, February 03, 2014, 03:41:21 AM
luckylulujoe13
Hello, I see that Small Bear is out of stock on the LDR recommended in the build PDF. I have read that some folks are getting the LDRs in a kit from banzai. Before I saw this, I was investigating getting some of the ones from China on ebay.
I have tried to grasp a close replacement with those available and found that maybe gl-5539 or gl-5549 were closest. Any help here, please. I'll attach a data sheet for the one out of stock at small bear and the ones I found.
By the way, if you know where I can get the right ones, I'll forgo all this...
luckylulujoe13
Here is the data sheet for the one small bear used to have.
Blues Healer
I noticed the other day SB were out of stock.
In the meantime, depending on your schedule, you might ask Steve for an ETA. I've done that before.
FWIW, I noticed he was at NAMM, and judging from my recent order, they might be a little behind.
"music heals"
luckylulujoe13
Thanks. I ended up getting a kit of 4LDR and bulb from banzai.
twin1965
I've used the Banzai ones on mine. They work perfectly.
Sent from my GT-I9100 using Tapatalk 2
