Help me find my next project.
Started by davidnlsw, February 03, 2014, 07:34:37 AM
davidnlsw
Just finished a "yellow shark" on a Haberdasher pcb (Thanks, Haber-er!) and I've been thinking about what I want to try next.
I have this empty case laying around the house leftover from a Christmas gift:
It's about 3 by 2.25 in. and around an inch tall.
So I thought I might try putting a simple project on perfboard in there.
Any suggestions on something pretty simple that would fit? I've never had a fuzz pedal so I'm thinking about going that direction, although I'm open to other ideas too.
You have lots of space for a circuit, but a switch is probably too tall and that case might not be robust enough to handle being stomped on. Therefore, I say go with an effect you wouldn't turn off: A foundation overdrive (amp sim of some sort), or perhaps a compressor. But if you want a fuzz that's pretty easy to make on perfboard and sounds great, I have several good ones in my perfboard layout. The Sam Ash Fuzzstainer is a really good one that I built recently, lots of good sounds in it and it's super rare. But if you just want suggestions on fuzzes, it's hard to pick just one. :)
angrykoko
that doesn't look big enough for 1/4" jacks.
How about a headphone amp, I've seen those done in Altoids tins.
The early bird may get the worm, but the second mouse gets the cheese in the trap.
davidnlsw
#4
Quote from: midwayfair on February 03, 2014, 07:45:57 AM
I checked the clearance for a 3pdt the other day and it will be snug, but should fit. I'm not that concerned with durability, it probably wouldn't find it's way to any gigs.
However, I have been in the market for a good compressor. Been eyeing the Xotic SP for quite a while, actually.
Any pert comp project suggestions?
I'll dig through some of those fuzz circuits.
Quote from: angrykoko on February 03, 2014, 07:48:35 AM
Again, it's gonna be snug but I checked for space yesterday and it'll do… barely. haha
Gledison
IF you dont want to spend to much in components i would go with a perfboard booster. treble booster or an LPB1.
cheers
Quote from: davidnlsw on February 03, 2014, 07:56:05 AMAny pert comp project suggestions?
Well, I'm pretty partial to my Bearhug. The library also has perf layouts for the Flatline (Afterlife), Engineer's Thumb, a couple Circuit Salad projects, ... let's just say there are a lot of compressors in there.
DutchMF
If you can fit a switch and jacks in there, I have a suggestion: Since it's a flip-top case, I'd choose a circuit that benefits from experimenting with diodes, IC's, transistors or other components. Maybe a Mudbunny or Greenbean?
Paul
Dye it red and put a Foxx fuzz tone pedal in there :]
davidnlsw
Thanks for the suggestions so far guys.
After digging around for an hour or so today, I still haven't found what I'm looking for. There are just so many perf/vero board layouts out there.
So I'm trying to refine my search. A fuzz or comp layout with a pretty small part count and only 2 pots. Does something that would fit the bill jump out to anyone?
billstein
Quote from: midwayfair on February 03, 2014, 08:19:25 AM
I can vouch for the Bearhug. That is a fantastic sounding compressor. Great design Jon.
Jabulani Jonny
Bearhug 2nd!  I haven't even turned it off since it made its way to my board. Seriously.
Jonathan
Bear hug is great, as well as the afterlife.
davidnlsw
Alright, a lot of love for the Bearhug. I think I might give that build a try.
However I don't think I could fit it in this enclosure I have, right?
