Author Topic: wah not wahing(SOLVED)  (Read 2113 times)
danwelsh
    • Eliquid in Canada
« on: February 09, 2014, 07:48:35 AM »
Hi guys, so i figured i should post a new thread now that i got the buzz gone on my weener.....i have no wah effect whatsoever, it's just acting as a volume pedal???
« Last Edit: February 22, 2014, 09:00:48 PM by danwelsh »
  • Billy
Re: wah not wahing
« Reply #1 on: February 09, 2014, 11:03:58 AM »
Check the transistor
rullywowr
  • Ben @ www.rullywow.com
    • Rullywow Industries - PCB's, DIY projects, and more!
Re: wah not wahing
« Reply #2 on: February 09, 2014, 12:16:33 PM »
The inductor could also be shot. I've had this happen before.
danwelsh
    • Eliquid in Canada
Re: wah not wahing
« Reply #3 on: February 09, 2014, 12:38:11 PM »
how would I test the inductor
rullywowr
Re: wah not wahing
« Reply #4 on: February 09, 2014, 01:58:24 PM »
Im honestly not sure. I would swap a known working one to see if it makes it go.
  • Billy
Re: wah not wahing
« Reply #5 on: February 09, 2014, 05:57:12 PM »
agree it could be the inductor too
A continuity check across the leads will show a broken coil, more precise measurement is a bit trickier
More likely you have a bad joint or trace somewhere inline with the inductor or transistor
danwelsh
    • Eliquid in Canada
Re: wah not wahing
« Reply #6 on: February 09, 2014, 07:14:20 PM »
i have continuity between two of the inductor leads but not the other two....should i have continuity all the way around?
Blues Healer
  • Solder Ninja
Re: wah not wahing
« Reply #7 on: February 10, 2014, 01:01:09 AM »
"music heals"
Clayford
  • Clay
Re: wah not wahing
« Reply #8 on: February 10, 2014, 08:55:08 AM »
The inductor and it's traces are the first place to start looking, and it depends on which pins are continuous and which ones aren't. They usually have continuity in matching pairs
1 - 2
3 - 4
1&2 have continuity as well as 3&4
or
1&3 and 2&4
Depending on which inductor you have - you might need to rotate it 90 to get some "wah"
  • Billy
Re: wah not wahing
« Reply #9 on: February 11, 2014, 07:32:20 AM »
Yeah, you might have it rotated 90 off.
Would be helpful to indicate what inductor you have if that doesn't fix it.
danwelsh
    • Eliquid in Canada
Re: wah not wahing
« Reply #10 on: February 11, 2014, 10:33:55 AM »
okay guys, i'll let you know what happens after i rotate it.
danwelsh
    • Eliquid in Canada
Re: wah not wahing
« Reply #11 on: February 11, 2014, 03:11:55 PM »
okay....so here's a picture of my inductor...i marked the two leads that have continuity together with a red marker, the other two don't have continuity....which way should this be positioned on the pcb? Or is my inductor shot?
« Last Edit: February 11, 2014, 03:38:43 PM by danwelsh »
danwelsh
    • Eliquid in Canada
Re: wah not wahing
« Reply #12 on: February 11, 2014, 03:52:45 PM »
okay guys.....figured it out, my inductor is shot. :(
danwelsh
    • Eliquid in Canada
Re: wah not wahing
« Reply #13 on: February 22, 2014, 09:00:28 PM »
Got my new inductor installed today.....and now i have wah effect....this is an awesome circuit :)
« Last Edit: February 22, 2014, 09:02:36 PM by danwelsh »
  • Global Moderator
  • Jimi Lee
Re: wah not wahing
« Reply #14 on: February 22, 2014, 09:14:43 PM »
No continuity should have been soldered to circuit, continuity solder to the bottom 2 holes if you haven't figured it out by now in case the inductor is good.
