Zero Point DLX Rotary Now 12 Positions?
Started by blearyeyes, March 04, 2014, 09:16:39 PM
blearyeyes
The Alpha 3 pole 4 position switch installed in my zeropint dlx build just decided to become a 12 position. Anyone ever seen inside one of these?
The spec sheet doesn't help.
Don't really want to replace it if I don't have to.
GermanCdn
Check to see if your position limiting washer (the black washer with the little peg with which you select the number of positions) has become loose or moved or broken.  It's the likely culprit.
blearyeyes
You saved me a lot of trouble... the new ones are silver and they work better inside the case with the pin going down than they do outside of the case with the pin going up.....HA!
Thanks!
