Author Topic: Calling all powder coaters  (Read 8340 times)
rullywowr
  • Ben @ www.rullywow.com
    • Rullywow Industries - PCB's, DIY projects, and more!
Re: Calling all powder coaters
« Reply #45 on: March 28, 2014, 07:18:36 PM »
Geez, I don't want, a powder coating setup, i neeeed a powder coating rig, right now, immediately. ;D You yanks are really spoilt for choice,(for most things)  ;) there's nothing cheap for sale here in Oz. I was looking yesterday and the cheapest rig i could find was near $600  :o, but i do have the compressor, toaster oven and a stepdown transformer already, so if anyone has a setup for sale or knows of a good deal going, let us know, thanks, Matt.
Hmm...that sounds like an rip off!  I got my gun for about $70 shipped on eBay.  The basic Eastwood gun like this:  http://www.ebay.com/itm/Eastwood-Hotcoat-Powder-Coat-Powder-Coating-Gun-/360873624032?pt=Motors_Automotive_Tools&hash=item5405be81e0&vxp=mtr
Since you have all the stuff already, all you really need is the gun, powder, and some grounding wire.  I would recommend getting a cheap moisture trap to put inline with the gun.  I also have a cheap air regulator on it as well.  The gun only needs like 5psi to work.  It's nice having the regulator inline so I can use the gun, and quickly switch to an air gun (at full pressure) to "clean" the gun by blowing the powder off it.  A lot of times, I will just "feather" the trigger on the powder gun because you don't need a lot of pressure at all.  Even the cheapest crappiest compressor will work just fine.
Fastocker
  • Transistor Tickler
  • Jim
« Reply #46 on: March 28, 2014, 07:40:41 PM »
Just to illustrate using multiple colors -- here's a vibe pedal I did with four coats of powder.  First I applied the black chrome on the bottom half, cooled it, taped it off with high-temp masking tape and then shot dormant burgundy base coat on top.  I let the dormant burgundy heat up slightly then pulled it from the oven to cool.  I removed the tape and cured the dormant burgundy base coat.  After that cooled I masked off the beltline stripe, shot that with bright red, cured that and then cooled.  Final coat was clear over the entire box -- it activated the dormant burgundy and did a nice job of smoothing everything out.  You can't even feel the stripe with your fingernail.
Lots of good info and technique tips here -- http://www.powder365.com/forum/ -- a lot of those guys are hardcore pros but there's a lot of good information to be gleaned over there.  Check out the CUSTOMER PICTURES section to see some of the gorgeous work these guys can do.
Owner of Unique-Vibe, LLC
www.facebook.com/uniquevibe
hoodoo
  • Matt
« Reply #47 on: March 28, 2014, 07:57:07 PM »
Hey Ben, the 600 dollar ones, were the cheapest i could find in Australia, 240v and all. I have seen the cheapies that are in the link you posted, but they won't post to OZ and the ones that do want a fortune to do so. :'(
rullywowr
« Reply #48 on: March 28, 2014, 08:36:12 PM »
Damn dude, I would offer to ship you one but the 110v may be a problem..pretty sure they are not switching but I can check tmro.
jimmybjj
  • Jim
    • BeeJive Pedals
« Reply #49 on: March 29, 2014, 10:43:18 AM »
Super smooth! Curious how high did you let the temp get to? Did you let the burgundy flow or just warm?
Pcbs no longer available
