IDA Tusk OD Proto
Started by GrindCustoms, March 29, 2014, 08:44:31 AM
marauder
Quote from: GrindCustoms on March 29, 2014, 06:34:40 PM
First reply and WIN! I can't seem to find my mouser bag of 82nf.. so i went with a 100nf...  ::)
That's the mojo out of the door, we all know the mojo is in the odd parts values, and unicorn tears.
BTW the Behemoth PCB is built and working, just waiting for John to do a decal.
GrindCustoms
Quote from: marauder on March 29, 2014, 06:57:30 PM
Haha! Indeed, just for testing out... the value swap does'nt hurt anything.. have some 82nf on their way, will swap the cap once they're in.
Yes Sir! John showed me the graphic layout yesterday....going to be killer! 8)
At first i thought you where going to build it for guitar, but you did it for bass, if i knew i would have sent you my build notes for bass... but John also showed me the change you made.. going to try some of that later today, some little differences with what i was doing, mainly R14 and that i was using a 390nf in C2... just to have a simplier BOM...
marauder
Quote from: GrindCustoms on March 29, 2014, 06:46:39 PM
I've at least took the time to build it on a card table.
My card table is like that where the drill bit has touched it.
We built a klone a while ago which the owner wanted more bottom, so did the C2 mod, but someone mentioned that reducing R14 to 1K5 from 15K added even more bottom.  Tried it and found it a little too mushy, so we changed it for a trimmer.
I  just chose the 4K7 as its around where the trimmer was set, sounds great.  Best bass OD I've heard through my non bass gear, a Crate Powerblock and a 1x12 with a 55hz celestion G12H.  Very Motorhead even without a Ric.
Quote from: sonarchotic on March 29, 2014, 02:12:20 PM
You didn't use those wizard's beard diodes. Just plain old human made ones.
Agreed.... :(
For the laugh....:
Have you compared the sound versus being built on a wooden table?  ;D
Thomas_H
Really interesting layout. I like it.
DIY-PCBs and projects:
GrindCustoms
Quote from: marauder on March 29, 2014, 08:29:01 PM
Nice!  8)
55hz... most human don't ear nothing from 50hz and below, your bass test rig qualifies! hehe
Quote from: jimilee on March 29, 2014, 08:30:14 PM
Agreed.... :(
For the laugh....:
I think we have another «science» case right here.
Quote from: Thomas_H on March 29, 2014, 08:50:18 PM
Thanks Thomas :)
I agree that most of my layouts don't have the «standard» component emplacement on them, truly made so you don't have to fight with nothing when populating. Everything is in dedicated component type section in rows.
From ground zero to completed built, that klone took me 1 hour to put together, so on a larger production scale.... where i built 20 to 30 at the same time, the average time per built once the whole task divided by units will be around 20minutes.
That's the time frame that i try to enter within all my production stuff, the Hydra on the other hand takes around 1.5hour when doing a single one, much more drilling and hardware allignement tho...
ddog
Wow really digging the unicorn skull on the back of the PCB. What the difference between the Chimaera and this PCB?
Is one aimed for the DIY community and the other for your in-house production of pedals?
Jabulani Jonny
STOP THE PRESSES!!
Is this board coming with it's own DPDT breakout board for buffered bypass?!  If that's so, I know where I'll be ordering future klone boards.  Nice work!!  I have to say that I do love the way you lay things out by component type.
Looks like I'll be building some more klones.  Doh.   ;D
Jonathan
Quote from: Jabulani Jonny on March 30, 2014, 03:09:01 AM
STOP THE PRESSES!!
This
GrindCustoms
Quote from: ddog on March 30, 2014, 02:56:13 AM
Both ChimaeraBFD and Tusk share the exact same schematic, just a layout difference.
But sadly yes, the Tusk layout (shown here) is for my production line only.
STOP THE PRESSES!!
I have some Chimaera Footswitch daughter boards coming in, they will come in packs of 2, featuring some usefull features! hahahahaha!
It's a small compensation, but it will still make the wiring far easier.
Aion's Refraktor does'nt fit in a 1590B? I was sure yes.
Jabulani Jonny
Quote from: GrindCustoms on March 30, 2014, 03:45:16 AM
[Aion's Refraktor does'nt fit in a 1590B? I was sure yes.
It does, and it's a great layout with board mounted pots, but a layout that comes with a buffered daughter board would be nice.
So you won't be selling these?
Jonathan
Looking good Rej. I remember when we first talked about these and I commented that there just wasn't an easy 1590B Klone build. Everything out there is geared to either bigger or smaller enclosures. Whereas I think the 1590B is THE enclosure to get effects into where possible (certainly to sell), as they take up little board real estate, yet are sensibly sized enough not to be a pain in the arse to build or use. Looks like you've nailed it mate!  8)
GrindCustoms
Quote from: Jabulani Jonny on March 30, 2014, 12:40:27 PM
No, i won't be selling these for now, once i get through my actual stash of Chimaera's, i'll update to this layout.
GrindCustoms
I've just put some of these layouts in the BuySell section for those interested.
