The Laying On Of Hands
Started by pickdropper, April 09, 2014, 12:41:49 PM
I haven't had much build time lately, but this board has been sitting around too long waiting to be boxed, so I snuck it in.
This is basically the first version of the EP Booster with the bass boost instead of the unity switch.  I added an internal 18V charge pump circuit as well as a switch to go between 9V/18V.  I think this will be useful for me for multi-builds as there is a switched 9V/18V output pad on the PCB for pairing it with another circuit.  I am planning on putting it with a Tube Screamer in a future build with the switch.
A couple of miscellaneous notes about the build:
1.)  If you can't read the text by the 9V/18V switch it's because the pedal is speaking in tongues NOT because I chose an absurdly small font.
2.)  I used a slightly lower CLR than I usually do with this type of LED, so when the pedal is turned on, you are blinded by a bright white light.
rullywowr
That is so tight.  Layout, laser etch, so clean.....Love those little blue caps too, they look like candy!  What brand are those?
Quote from: rullywowr on April 09, 2014, 12:45:00 PM
Those are TDK MLCC caps (stocked at Mouser).  I'm a really big fan of those.  Those are big ones, too: 10uF/25V
wolfingsworth
Awesome work again Dave! I hadn't heard anything about the EP booster but it must be good if it's worthy of a pickdropper build!
Gotta say my prayers!  This could only be more awesome if you had a blue dip sw.
Tremster
#5
Very, very cool. As always.
Edit: you should start your own pedal company.
I had an EP Booster and liked it a lot. But then I got into DIY, built several Fatpants, and sold it.
Did you compare the two?
Huh, Pickdropper's a Paladin. And here I was sure he was a wizard.
That is so beautifully done Pickdropper. Wow
Quote from: midwayfair on April 09, 2014, 01:34:14 PM
I'm a Manna of many faces.  :-)
Clayford
Paladin's are just Church approved mages. Dispensations can be made to allow for "other" learning. Just ask Sparhawk ;)
head solder jockey, part time cook: cranky&jaded
All this talk is making me miss my D&D books!  ::)
Yep... I'm one of THOSE guys!!  8)
Pick, your just determined to get your font size under 10 points with that laser aren't you? lol
That PCB looks great in there. I lust love your layouts.
chromesphere
Hey Dave that looks great but when are you going to wire it up?  Oh wait I think I can see a wire there? :D
Stomptown
This is awesome Dave! Very clean and the black PCB looks killer. If only the 3pdt board were black!  :o
