Author Topic: Working out power ratings  (Read 956 times)
Gaslighter
  • Diode Destroyer
    • View Profile
« on: April 29, 2014, 07:14:59 AM »
I've noticed that some boards come with a shopping list of components whereas others don't. I want to build the smoothie and would like to know how many watts the resistors need to be. Grateful for any help.
  • Electron Doctor
  • Lee
    • View Profile
Re: Working out power ratings
« Reply #1 on: April 29, 2014, 07:21:29 AM »
With pedals, 99+% is 1/4 watt resistors. You can assume that 1/4w will do unless otherwise noted in build documents. Some designs are very dense or very compact and would require 1/8w for space savings. There are probably high voltage tube designs that would require 1/2w or higher. 1/4w is just right size/power wise for pedals though.
Welcome to pedal building and to the MB forum! Keep asking questions. This is the place for it!
Lee
RobA
  • Electron Doctor
    • View Profile
    • Music Unfolding
« Reply #2 on: April 29, 2014, 07:24:25 AM »
The Smoothie is one of the baby boards, so additional build info is in the doc for all of them (http://www.madbeanpedals.com/downloads/BabyBoardGuide.pdf).
It calls for 1/8W for the baby boards because of space constraints. 1/4W will work, but you have to partially stand them up and it won't fit in the 1590A box then.
Gaslighter
  • Diode Destroyer
    • View Profile
« Reply #3 on: April 30, 2014, 02:47:41 AM »
Thank you both for your help!
