Faultline / Catalinbread SFT
Started by Hexjibber, May 05, 2014, 12:12:37 PM
GrindCustoms
You ain't human, you're a Laser!!!
Badass work! :o
Haberdasher
dang, that looks awesome man!  helluva good job.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
hoodoo
Super nice, intricate etch mate, very impressive  :)
Morgan
Wow - that's insanely nice!
I felt that this is one circuit that is night and day different at 18 volts. I like mine a ton better at higher voltage, FWIW.
Moderator at BYOC, still sometimes futz around with Leila Vintage Electronics.
Old Blog...
Thats bloody awesome.
AMAZING etch dude!
Hexjibber
Thanks for all the cool feedback guys, great to have a forum where we can share our work, it's a constant source of inspiration for me!
Quote from: Morgan on May 05, 2014, 09:50:32 PM
I'd like to try it at 18V as my PSU can do 12V and that certainly made a difference, the sound is almost there on my build but I'd like it to have a bit more balls to it! I also found that this circuit seems to prefer a clean signal rather than overdriven, anyone else found the same?
hylandren
I know you chemical etch, but the fine lines on this one are so sharp that it looks like a laser etch.
Great graphics design as well. An inspiring build on all levels.
micromegas
This one is one of the coolest/cleanest etches I've ever seen.... I might have to switch from FeCl to your method....
Software Developer @ bela.io
Guybrush
Quote from: Hexjibber on May 06, 2014, 02:11:06 AM
Hey man
Such a great etch. Don't know if you remember but you helped me over on DIYSB with my etching process. (I'm called Threepwood over there and we realised that we both live in Brighton).
Anyway, I bought an 18v convertor from GAK in to try with my Faultline. Maybe it's something wrong with my build but it really didn't sound good.
If you want to try it out let me know and I'll get the adapter to you. It's be good to know how you're sounds at 18v.
Morgan
Quote from: Guybrush on May 08, 2014, 01:22:04 PM
Hey man
FWIW - I was pretty picky with the fets on mine. I sorted until I got what I wanted at 9 volts. Then when I tried 18v, I sorted fets again until i got the best response (did not use the same ones that sounded good at 9 volts). For my build, it was all about the 18 volts though! Sounded mediocre until then.  ;D
Old Blog...
Guybrush
Ahh ok. Can you remember what you fets you used for 18v?
Sent from my HTC One using Tapatalk
Morgan
They are all 2N5457 (I think that's what's recommended). But what I meant was, that I swapped individual devices (not part numbers) until I found a set I liked. The gain of those fets is not consistent. Also, I was looking for good clarity versus the most gain.
Old Blog...
Guybrush
Thanks, I understand.
Hexjibber
Hey man
Hey dude! Yeah I realised it was you man, also a fan of Monkey Island! ;)
I ended up putting a charge pump in it the other day and for me it definitely sounds better (more gain and general oomph) although not markedly different from when I was running it at 12V to be honest. Listening to your video though I wouldn't say that yours sounds like mine did at 9V, more like mine does at 12V/18V so perhaps you were luckier with the transistors than me? I'd be interested to see if I can squeeze some more gain out of mine as it's still not quite in the same territory as the Catalinbread vids, I've been using a Timmy as a clean boost to nudge it into more saturation at the moment.
Is there a way to measure the gain on these FETs so I can avoid too much guess work do you know?
Guybrush
That's ones beyond be I'm afraid. I'm sure someone will know.
