SMD 2n5088 in eagle and best substitute?
Started by brejna, May 12, 2014, 05:36:31 PM
brejna
As the title says, what is SMD 2n5088 device in eagle and best sub for it mmbt3904 or?
Brane
I am nearly positive that you can just use an MMBT3904 in Eagle and the pinouts are the same.  Just to be sure, I'd recommend double checking the datasheets.
There is an SMD version of the 5088 and the 5089.  I can look it up later if you can't find it.
brejna
brejna
BTW if you have some kind of SMD library to share it would be awesome :D
