Sun King II
Started by sdlogan9, May 30, 2014, 05:31:08 PM
sdlogan9
Hey Guys
   I just finished my build.  I must say..  Props to Madbean here !!!  This build is fantastic and by far the best sounding Klone I have build yet.
Hangingmonkey
Really dig the white sparkle, is that a PPP powdercoat
sdlogan9
Ya-  I got the enclosed from PPP..  I really like there stuff!!
That looks great, love that color also. Also, great job on the switches. I am having to rework my template on mine since I can not seem to get the toggles to play nice under my 1/4" jacks.
sdlogan9
#4
Quote from: selfdestroyer on May 30, 2014, 09:45:16 PM
As you can see in the photo's I used long wire leads formthe switches and mounted them underneath the PCB..  not where the build instructions recommed them to be mounted..  as that will not work..  the jacks get in the way.
I used the recommeded switches in the build instructions(  10TC410  )..  I had to order them from Mouser(Small Bear was out of stock).     Then I had to make sure I drilled the switch holes underneath the PCB.  Next step is to bend the three barbs on the switch down- to make them shorter(so it will fit underneath the PCB) and take off all of the extra washers and bolts so the switch will sit as low and close the the enclosure as possible.    I messed up 2 enclosures before I got all this figured out(I drilled the holes in unusable places).    Last tip I would have would be to solder the PCB on the Pots up as high as possible to make plenty of room underneath the PCB.
I know this is kind of wordy and probably a bad explanation of what I had to do..  but I hope it helps some:)
You have definitely helped me out in the past Cody :) !!
After all of the work involved after building the pedal...  in the end I must say it was all worth it!!  This is by far.. and I mean by far the best sounding pedal ever!!  Once again major props to Madbean here!!!!!
-Shane
bela1961
Two days to populate and solder board for testing. Works great, time to box it up, No sweat right? WRONG! 9 hours of thinking, changing wire length's, etc. I only wound up with 2 extra holes, which I can fix pretty easily. Now, for the reward, what a gain monster! and what sets it apart is being able to tweak so many parameters. I don't know if it sounds exactly like a klone, but who cares, who needs a klone when you've got this. Thank you Madbean.
sdlogan9
Good to hear you got it all working Bella!!
