Double flush tremolo - Pot substitution
Started by Gledison, June 10, 2014, 07:35:19 PM
Gledison
Hey guys,
I have only 10K log to use for the intensity pot. I know that is ok to substitute in certain cases but im not sure here.
I believe it will just respond slowly (have to turn more for higher intens.) but still do the job. is this correct?
thanks
Gledison
Gledison
Quote from: flanagan0718 on June 10, 2014, 08:16:12 PM
I might have a B10k. You state side?
Thanks man, but im in Germany :P
no worries i could get a pot relatively easy here, i was just wondering if i could use a log instead of a linear for the intensity.
Cheers mate!
Should be fine to substitute.
Where about in DE? The company I work for is based in Tuttlingen. Its a 2 hour train ride from Zurich.
Gledison
Quote from: flanagan0718 on June 10, 2014, 08:57:49 PM
Mannheim, 1 hour from frankfurt!
GrindCustoms
I have'nt look at the schem or build doc or the Double Flush, but if Intensity, works like a Depth control or for the width of the trem wave... a Log pot will be boring to tweak. You'll start to feel it's action way too late in it's rotation and in most case keeps you away from the «sweet spot».
Ah nice. I need to go again. Been itching for some good kesse spetzle
Quote from: GrindCustoms on June 10, 2014, 09:44:44 PM
It's a series resistor with the LED as a current limiting resistor.
A B or even C taper is better. I wouldn't use an A taper.
Gledison
That's what i was afraid of!
I will get the right one! As it should!
Thanks John for the explanation. I understood that part, just thought that would still work with a non linear resistance adjustment. But yeah, most of the settings will start turning the knob all the way up!
Thanks!
Gledison
Thanks!
Gledison
Quote from: midwayfair on June 11, 2014, 01:50:34 AM
Hey john,
if the pot is working as a CLR, it would be possible to use a higher value right? like 20k instead of 10k. i believe than, the max will be in the middle position, with no change after that....???
cheers
Quote from: flanagan0718 on June 10, 2014, 09:44:52 PM
Kässpätzle is one of my favorite dishes. Also available in Austria :D
Quote from: Gledison on June 11, 2014, 05:18:48 PM
Hey john,
cheers
Max is when it hits 0.
The issue is when the resistance gets LOW enough to start having an effect. So a 20KB might be bunched up in the same was as a 10KA.
Gledison
Quote from: m-Kresol on June 11, 2014, 05:40:27 PM
Heheh! Yes its good but extremely high caloric! Normally i eat when im off for skiing :)
Gledison
Quote from: midwayfair on June 11, 2014, 05:44:02 PM
Hey john,
cheers
The issue is when the resistance gets LOW enough to start having an effect. So a 20KB might be bunched up in the same was as a 10Ka.
Im being a lazy Ar§%&&%/()Ä'* here. :P
The prob is that im going for holiday (Worrlllld cup) and dont want to bother to geta 10Kb pot.
What about taking a 20Kb pot and add a 20K resistor between lugs 1 and 3 ? I know that wouldnt be a 100% like a 10k B pot but would be ok to use as CLR here?
cheers
