Bax30 - HV Content - Clip!
Started by GrindCustoms, June 15, 2014, 02:23:41 AM
GrindCustoms
Quote from: juansolo on June 15, 2014, 08:57:45 PM
Quote from: GrindCustoms on June 15, 2014, 07:26:18 PM
These circuits other than the 1W power amp i did are made from the schematic made by Juansolo and Marauder you can find them in the tube section of their website.
Not quite, I haven't taken Cleggy's hand drawn stuff and made it pretty yet ;) It'll be up after ours is put together (later this week). Working from them at the mo.
With all respect given to the mojo... a circuit built from an hand drawn schematic sounds better! hahaha
MarcFive
Quote from: MarcFive on Today at 02:25:42 AM
What, no effects loop?
Hmmm.... i think i don't get it...., would you put an effect loop in a TubeScreamer? :o
Is joke. Haha... No?
GrindCustoms
Quote from: MarcFive on June 15, 2014, 09:34:27 PM
Joke it is then!
I just thought i was maybe not getting something... you know... i'm just an arrogant frenchie after all ;)
But YES! PCB layouts are in the work for these circuits and PSU wich will be offered as a full kit (couple non-common parts, will be easier that way).
Sold!
Quote from: GrindCustoms on June 15, 2014, 09:14:40 PM
Ok, Mojo preserved, I've stuck it on the valve buildage section of my site ;)
http://juansolo.demon.co.uk/stompage/btbuild.html
GrindCustoms
Bax30 Crap Clip!
Vox AC30 input stage with Input/Output tube buffer with Baxandall 2Band Eq
Gain stage tube: Brimar 6BR7
In/Out buffer tube: RTT 12AU7
Guitar: Schecter Tempest Custom w/Suhr Aldrich Humbuckers, both pickup position. Tuned 2 whole step lower.
Signal chain:
Guitar --» Klonish Buffer --» GCFX RottenKomp --» GCFX Catch22 OD --» Bax30 --» Decimator (filtering, no gating) --» Mesa Mark IV Clean Channel --» FX Loop (Ibanez AD9 --» RaD DLX Reverb) --» iPhone w/Tascam iM2
GrindCustoms
Well.... i guess it sounds like shit.... ::)
Tonight i was working at the theatre, had a Soul/R&B band, guy had an old rental solid state Randall amp.. that was really not giving justice to is playing (band is from Montreal, 8hour drive from my location) So instead of having him play through that amp, i brought the Bax30 and we run'd it directly into DI to PA... sounded awesome.. just like an amp...but so much in your face since it was direct line.
The show was recorded on protools via the the Venue SC48 we use, live sound clip to come! ;)
I would leave a comment, but this kind of work is above my paygrade.
Thankfully you said it was only "decimated". I was afraid you were going to say things were obliterated, annihilated, or destroyed.
How hard is it to DIY a DI box... Could make an interesting pedal indeed if it had a balanced out on there as well...
GrindCustoms
Quote from: juansolo on June 21, 2014, 07:32:45 AM
I've got some Jensen and Cinemag transformers that i ordered in the beginning of the week. When i started to play with this pedal it's the first thing that came to my mind....
A passive DI is one the easiest thing to do, especially when you have «fixed» sound level input. By that i mean, that what is driving the transfo will not vary. So you can have a fixed pad and all that... so yeah... 1 Transfo and 3 resistor...and.... ROCK! 8)
Stupid easy. http://store.diyrecordingequipment.com/ferrite-passive-di/
