Applying Sunking bass mod values to Kingslayer?
Started by thesameage, June 24, 2014, 06:14:29 AM
thesameage
In the Sunking BOM, there are a number of values to try for better use with bass. The components in the two (obviously) do not match up, though many are the same. Is there a way to apply the Sunking mods to the Kingslayer?
Here's what's suggested in the Sunking BOM:
C2: 220n
C3: 1uF
C4: 220n
C5: 100n
C6: 220n
C7: 100n
C8: 270n
C9: 1n
C12: 6n8
C13: 56n
C14: 1n
C15: 10n – 15n
R16: 6k8
sdlogan9
I am interested in this too
The christening valve amp mistake is to get the primary wires for the OT the wrong way around (giving howling, screaming positive feedback, NOT negative), but I don't think that's possible in a single ended amp like a Champ.
blearyeyes
I'm trying to learn this stuff but I'm not really up to speed. You would have to look at the schematic and figure out where the R/C filters are (resistor / capacitor). Raising the cap values will let more bass through and less highs. There is a great software suite of electronic calculators free here:
http://www.electronics2000.co.uk/download.php
thesameage
As brian/madbean has said recently, if you change the values in some parts of the circuit, you'll need to change the values in other parts to compensate. That said, I'd love to hear his input as he already figured it out for the Sunking.
blearyeyes
#5
Been lookin at both schematics and you might be able to identify each change by putting them side by side and figuring out which number corresponds with the same component on the other schematic..  They are very similar.. Then just substitute the numbers.
+1 thesameage
All components in a circuit work together. Still....
blearyeyes
#6
Sunking = Kingslayer
C2   = C4 220n
C3   = C5 1uF
C4   = C2 220n
C5   = NOT INCLUDED (no thick switch)
C6   = NOT INCLUDED (no thick switch)
C7  = C8 100n
C8  = C7 270n
C9  = C9 1n
C12  = C13 6n8
C13  = C14 56n
C14  = C15 1n
C15  = C16 10n - 15n
R16 = R20 this is already 6k8 on the king slayer
If you decide to do these modifications realize I am not Brian and I do not guarantee these will net the results you want. All I did was locate the same component on the Kingslayer that was on the Sunking and translated the part number. Please double check the values as I copied them from your post and not from the suggested mod by Brian.
thesameage
blearyeyes
If you do this, let me know if it works.
Good luck.
Here is what Rej told me while I was building the Chimaera:
To make the Chimaera BFD Bass guitar friendly change C1 to 390nf
So just the inout cap. Sounds good to me.
thesameage
Quote from: blearyeyes on July 13, 2014, 08:04:54 PM
Good luck.
I plan to do it and I have a board... just distracted by another build temporarily!
the3secondrule
Has anyone tried the above mods?
I've got a kingslayer board here that getting these mods unless someone can give me a good reason not to ;)
thesameage
