lavache only clean
Started by copachino, July 07, 2014, 04:13:51 AM
copachino
hi all.i have a new problem im building a lavache for a friend, cos he has kidnapped mine, so i etched a new one, the problem its that i only get clean sound, and only happens when i connect the ring of the jacks, if i ground the rings the are no sound, or noise, the volume pot seems to be working but, i cant figure out what its the problem the clean sounds even if i take out the transistor, i have change the caps, and the transistor even jumper the pots and switches and its the same result, any idea where to start??
Got any photos at all? :) (I like the LaVache, right up there with the Cosmo.)
copachino
Quote from: alanp on July 07, 2014, 06:46:36 AM
here are some, but not really good quality, i have tried eveything on my hands, but i cant figure out, how the signal passes the input and get the output, without changing at all.
Odd, the ring of the jacks (assuming a tip-ring-sleeve jack) should not do anything in a stompbox situation.
copachino
Quote from: alanp on July 07, 2014, 09:15:39 PM
sorry i missconfunse me, its the sleeve, if i joins sleeves, i get clean sound, if i ground sleeves i get nothing, if i leave sleeve unconected i get noise... its really extrange because without power with the sleeve joined, i get clean sound still, but i know the signal passes the circuit because i unconnected the vol knob and if i jumper that, i get the clean, if i leave it unconected i get nothing
Make sure your polarities are correct. Signal passes when you join sleeves because it bypasses the board all together.
copachino
Quote from: jimilee on July 07, 2014, 11:04:43 PM
recheck polarities, and its OK, i dont think but, i didnt have 3,3Mohm resistor so i use 3.0Mohm that could affect sound, but i dont think it make the pedal useless
Nope won't affect it at all. Got clear pictures of both sides of the board?
copachino
#8
i will post it tonight
copachino
copachino
i got tired from checking and doing many things that last night just unsolder everything, and rechecked the pcb to found that the input was grounded, that why i get clean when i join the slevees, and got nothing when the effect was grounded, it was a very small trace of copper in the potenciometer pad, i cutted and im resolding, i think this time its going to work fine
