Lace's Alan's DoubelGanger Help needed SOLVED!
Started by blearyeyes, July 18, 2014, 04:28:38 AM
just get some decent snippers and cut each leg of the ic socket, then suck out the solder and bit of "leg" that is left
Its clearly an issue with the build that you need to address before anything else can move on....
The reason I ask for full board pics is to check values etc.
https://www.gigaheartsfx.com
instagram @gigahearts_fx
blearyeyes
do these boards have through PCB pads?
#18
Yes, they are standard 2 side through hole plated...
you have got the pedal controls hooked up properly, or at least jumpered the pads, right?
not had time to look at resistors but the cap values and orientations seem legit
blearyeyes
#20
I'll go through the values.
What could possibly get power to the indicator LEDs and have them blinking (although seemingly dimly) when the bypass switch is lifting the ground to the circuit.  Must be getting shorted to ground somewhere in that circuit...
I'm going to write down all the pieces to this puzzle and post them in one place.
Short, solder bridge, who knows.
The pcb was triple verified... So sorry to say it's an error your end dude  :-[
blearyeyes
#22
Ian, I totally agree. Like for instance, having the indicator LEDs in backwards?
I would say that qualifies as a pretty stupid error on my end... :-[
I replaced the IC3 socket, which I think started this whole ordeal..
Nothing like pedal building to keep you humble.
Sheesh.
Thanks again for all your help guys...
Dan
blearyeyes
Quote from: alanp on July 21, 2014, 05:01:13 AM
Is your pha.a2 connection going to the ground pad?
QuoteI am getting the main leds lighting while the indicator leds are dark, and the indicator leds lighting when the switch is in bypass...
This is what really has me confused -- not sure how it's possible to manage that one!
Well if you wire the indicator LEDs in backwards.
blearyeyes
#25
Yes It sounds awesome!
I am getting the hang of the controls.
Very cool pedal.
Nothing else like it really.
This is a definite must build!
