Neutrino/Slambox Combo (Switchable Order)
Started by tenwatt, April 23, 2011, 09:04:49 AM
tenwatt
I want to put a Neutrino and a Slambox in one enclosure with two footswitches.  I want to be able to stack the two or run them both individually.  I would also like to put a switch on it that when thrown one way, the Neutrino would be the first in the signal chain.  When thrown the other way the Slambox would be the first in the chain.  Does any one have a diagram for such a build?
Not too bright....
maysink
[nothing to see here]
-e
Fastocker
Here's a diagram I found online that works.  The two lower switches are normal 3PDT stomp switches, one for each effect.  The upper switch is a 3PDT toggle switch for switching the order of the two effects.
Owner of Unique-Vibe, LLC
www.facebook.com/uniquevibe
