Pork Barrel Noisy LFO - FIXED
Started by wilsona, July 29, 2014, 06:00:21 PM
Quote from: wilsona on August 07, 2014, 05:14:21 AM
I've screened the pots from the pcb using copper foil, with only the last cm unshielded, and the I/O wires from the pots and PCB, so I assumed that was sufficient. To braid them I would have to affix longer wires  to the pots but I can try it if you think its worth it. Unfortunately I decided to put the jack sockets at the top of the box, so everything is a bit open up there, and the I/O wires run the whole length of the enclosure under the PCB.
Regarding the cap on the MN3101 - I was just going to use a non-polarised ceramic but I might have a suitable size electrolytic around.
Never assume, shielding helps but it's better to have short wires in the first place.
No i'm saying DON'T braid them, I wasn't sure if you had or not  :)
Don't put the cap on the MN3101, put it across IC2.
blearyeyes
I have a Pork barrel without any extra shielding and it is quite. Most likely you have a cold solder joint somewhere or a solder hair, something shorting out or a bad component. Re-flowing solder joints is your friend. I have never braided pot wires and rarely see it done for anything other than cosmetic reasons. Did you find anything by tapping the components?
wilsona
Just want to be clear - I'm putting the cap between 4 and 8 on IC2, which is the op-amp.  Anything from 100nf to 100uf, if electrolytic then negative to pin 4, positive to pin 8. Right?
I will go round a re-flow it too, I did reflow everything around IC3 and 4, but I'll do the whole board.
Have not done a tap test yet.  Been a bit side-tracked, building a new telecaster.
Thanks.
Quote from: wilsona on August 09, 2014, 03:37:54 PM
Thanks.
Correct, i'd go for the higher end valued electrolytic, 47-100uF personally.
wilsona
I happened to have 20 (!) spare 47uF 25V electrolytics so used one of them - sorted! The pedal is nice and quiet, no hint of LFO in the background anymore. Now I'll just have to work out how to close the case....
Still got a slight problem with distortion - I'll open another thread for that if it bugs me enough (it probably will).
I can't thank you enough for all the help. I have learned so much from you all.
blearyeyes
#20
Buy a Road Rage and run this @ 15v, more headroom and nicer sounding.
No more distortion...much better.
RobA
Excellent.
I'll give a big second for doing a 15V mod. It really helped mine out. I set mine up to run off an 18V input from my DC-Brick and then I regulated that to 15V using a little breakout board for the regulator circuit. I did sound better that way.
Now that I have an MN3207 in there, I had to run it back at 9V and there is some definite noise with it at that level.
If you've got the MN3007 in there, I think it's definitely worth powering it at 15V. Just make sure it's a solidly regulated 15V since you are pushing the limits of the BBD at that level.
Quote from: RobA on August 11, 2014, 09:21:10 PM
Just to clarify max voltage is actually 16V with 15V typical, 18V is terminal, so there's a bit of play, just don't push your luck ;)
RobA
Quote from: Scruffie on August 11, 2014, 09:36:43 PM
Yep, I'm just a bit extra twitchy with these since they are getting to be difficult to source. But, I shouldn't overstate things. The extra few hundred millivolts that always seem to be there over the stated value for a regulator aren't going to hurt anything.
wilsona
Well I do have a spare 3007! And I also have a Road Rage - just don't think I can fit it in the box....
