Mudbunny: Putting the mid pot on a switch?
Started by henryadams, April 26, 2011, 12:54:38 AM
henryadams
Ok, ok. I think it was just some sloppy soldering.... ::)
k.rock!
God bless!
www.kalebromero.com
henryadams
Well, I've learned some things: I tried wiring up the mid pot and mid switch the way jkokura mentioned, and I'm pretty sure that's not the right way. I got no mid-enhanced sound, the pot did nothing, and in fact I got a volume drop. Just to be sure I switched into "regular muff" mode and twisted the mid knob to make sure I didn;t do the LED backwards, and nothing there either. So I rewired it my way, and the mid knob works again. The main switch no longer pops. But there IS a pop back in the mid switch. It's not too bad, so I might just live with it. The only thing I can think is that the pot needs to be grounded. So I'm thinking I'll just solder a wire to the back of it and run it, too, to the output jack. Then I will seal up the back of my muff and never, ever again peek inside.
Thanks so much, Kaleb and Jkokura for the help and suggestions. This site and TDPRI are my favorites, because of the good folks.
