paradox TZF repair
Started by jryder, August 08, 2014, 04:46:03 PM
jryder
Greetings, I just registered on this forum, and I have a question about a pedal I am trying to get working.
I have a FoxRox Paradox TZF (flanger) pedal. I recently inherited the pedal from my dad. It has no visible signs of wear, and was kept in excellent condition. However, my problem is that I cannot get the pedal to turn on. I am using a 9VAC adapter (brand name Jameco- ReliaPro).
I'm interested in selling this peddle, as I understand it is somewhat rare and sought after. Do anyone have any advice on how I can get it working, or if needed, where I can find a reliable repair service?
Any help/advice would be greatly appreciated. Thanks.
chordball
Is the guy that does foxrox still in business? Back when I had a captain coconut the vibe section quit on me and he repaired it for free. I wasn't even the original owner.
If he's not, first step to repair will be to verify power is getting in to the circuit, I assume you have a multimeter?
Foxrox very much in business and Dave fix stands behind stuff 100%
I would not be suprised if he fixes it for free at all
https://www.gigaheartsfx.com
instagram @gigahearts_fx
I don't think you have to worry too much about fixing it. Even in it's current state you will have no problem getting someone to pay handsomely for one of those. That is one of the most sought after flanger pedals of all time.
Angels and ministers of grace defend us...
Ill give you £250 for it broken   ;D
jryder
Thanks for the advice guys. Wow i knew it was rare.. but didn't know it was that rare. I actually contacted foxrox, and they said the most common cause of this issue is an incorrect power supply. I do not have a multimeter, but the guy from foxrox told me if I don't hear the 9VAC adapter "buzzing" when its plugged in, then it's probably not working (mine doesn't buzz). I'm ordering a new one online.. so I'm hoping that will be the easy fix. I'll be in further contact with Foxrox if it needs actual repairs done.. they seem pretty solid with customer support.
I'd prefer to have this badboy in working condition so I can get the most money for it.. and I also want to play it some before giving it away. Thanks again for the help.
It's amazing, never sell it you fool!
are you sure you have the centre pin of your power supply negative? many other devices use the pin for positive 9V... with most of these cheap all-in-one power source you can just take the jack of the cable and just insert back it 180° turned
hope that makes any sense...
Quote from: m-Kresol on August 12, 2014, 04:58:14 PM
Its AC  NOT DC
so all that is irrelevent, sir.
Quote from: LaceSensor on August 12, 2014, 05:41:41 PM
Its AC  NOT DC
oh, I've missed that. Sorry
If you fix it and try it out, you'll never want to sell it, then none of us have a chance!
Are there any good gut pics of this someplace? Would love to see some detailed under-hood shots!  8)
Quote from: Govmnt_Lacky on August 14, 2014, 02:42:41 PM
search...  some in the request thread for it (!)
