Zombii Q2 and Q3
Started by tenwatt, April 30, 2011, 05:25:08 AM
tenwatt
I just ordered all my parts for a Zombii build and couldn't find Q2 (GE PNP 70Hfe) and Q3 (GE PNP 110Hfe) anywhere.  Where are you guys getting those?
Not too bright....
audioclone
Get the fuzz face set from Small Bear electronics. Caps N Such can help you out as well, way cheaper solution.
http://www.smallbearelec.com/home.html
http://www.capsnsuch.com/
bigmufffuzzwizz
yea caps n such or maybe even effects connection could help you.
lwatford
Quote from: audioclone on April 30, 2011, 06:53:07 AM
I've built a pair of them so far, and just used the least expensive pair from smallbear. They work great, though if you plan on putting them in a b sized enclosure they are tall, and a 3pdt might not work if you want to use a battery too. Just takes some planning.
tenwatt
So I ordered a Fuzz Face package of Germaniums from Small Bear.  They're marked "101 L=89" and "157 L=148".  They also sent me four resistors.  They're marked R3=80K, R4=680M, R5=11K, R6=120K.
To get the true Zombii (Fuzz Factory) sound, do I just build the circuit using the Mad Bean values for the resistors or do I need to sub in the resistors sent to me by Small Bear some how?
Not too bright....
bangerang101
 Yeah, for the closest sound to the real fuzz factory, you probably wanna use the resistor values in the madbean documentaion. The values they supply you w/ were probably for a regular fuzz face...
Owner of Luck Duck Pedals (LDP)
night-B
You can get some germanium ac128 tested with all the hfe you want at Banzai music  :D
tenwatt
Quote from: night-B on May 10, 2011, 06:09:27 AM
I bet the shipping rates would hurt my feelings though.
Not too bright....
night-B
I usually pay 10$ of shipping to France from banzai
tenwatt
Okay...so I built the circuit tonight and I "rocked it". It's still unboxed.  Immediately, upon turning the volume up on the circuit, it's squalling some feedback.  When I hit a note it stops but as soon as I mute the note it immediately starts feeding back again.  It seems to be a lot less controllable feedback than the demos I've seen of the Fuzz Factory.  Could it have anything to do with the germanium values being so far off ("101 L=89" and "157 L=148")?
Not too bright....
Means you need to play with pots a bit. One of them needs to be turned up not down.
jtn191
it'd be the "stab" pot, which is short for "stability"
tenwatt
Quote from: jkokura on May 10, 2011, 08:05:45 PM
Ha...yeah...I figured that out after I made the post.  I hooked it up an giggled each knob but I didn't sweep through the whole range of the pot.  The "Stab" knob is the culprit.  This is a crazy circuit.
How much does the value of the germaniums effect the sound?
Not too bright....
