Updated: Terminus - Buffer, EQ, Cab Sim, Master Volume, Balanced DI
Started by Willybomb, September 14, 2014, 09:30:21 AM
Willybomb
It Lives!! Behold Terminus!! It's end of the line for your pedalboard chain! Buffer, EQ, Cab Sim, Master Volume and a Balanced Direct Out!
It started with this question here:
http://www.madbeanpedals.com/forum/index.php?topic=11129.0
And it built up from there....  I finished the box this week, and spent about 5 hours soldering the boards in today.  Like the Random Stranger, it started out neat...
It has:
http://tagboardeffects.blogspot.com.au/2011/04/klon-buffer.html
http://www.madbeanpedals.com/forum/index.php?topic=11678.msg105603#msg105603
http://www.diystompboxes.com/smfforum/index.php?topic=97041.0
http://www.sabrotone.com/?p=3899
http://www.madbeanpedals.com/forum/index.php?topic=14276.0
As soon as I can find the tayda knobs I purchased ages ago, I'll stick them on and upload a completely finished pic...
muddyfox
Oh man, I gotta build this.
I don't need it at all but I just gotta...
Willybomb
#3
QuoteThat's a great idea - and well executed, too.
Thanks.  Basically I play through a powered wedge, so I needed something to control the volume from the pedalboard.  Dunno about the well executed bit, but it's about as good as I can do on vero with my attention span.  I'll probably go back and tidy it up somehow later...
I probably could have gotten a ZoomGX3 (and probably still will for another pedalboard) and got the same (more) functionality, but I like that it's basically an amp front end in a box.  Easy to adjust.
QuoteI don't need it at all but I just gotta...
Lol, good luck, post your results when done.  I wonder if I can get Brian to do a PCB...
Great concept and fantastic build! That represents a ton of work. I love the name and artwork too!
Willybomb
Here we go, the knobs arrived today. I also cleaned up the guts while waiting for them to arrive.  The vero doesn't always stick to the double sided foam tape (expensive 3m stuff!) so it got a dose of hot glue to stick the vero to the tape.
Willybomb
Another update.  This had a few intermittent problems with a few cold solders after a while so I took the opportunity to do some stuff that was bugging me, mainly the eq/boost section.
I've replaced the eq/boost with a marshall tonestack and LPB1 on the same piece of vero, layout courtesy of Tagboard.  I'd cannabalised the original white knobs for Deadringer, so I put some black ones on that I had lying around.  The boost isn't as loud as the Gus's PNP boost, but the eq is far more usable than whatever I had in it.
bluescage
