Author Topic: Green bean help?  (Read 3130 times)
murdog47
Re: Green bean help?
« Reply #15 on: September 23, 2014, 04:30:52 PM »
I feel like I missed something.  Is there an LED and a CLR between your power jack and your 3PDT footswitch?
I think there is we just can't see it in the picture.
  • Dinner at Dorsia? No problem...
« Reply #16 on: September 23, 2014, 04:42:21 PM »
Ok well a quick check for a short would be to measure resistance between the 2 poles used on the DC jack. If you see something less than ~200 ohms then you have a problem. If not then you need to post voltages on the IC legs and the transistor legs
Also, as said before, get rid of the yellow wire from the output jack sleeve to the stomp switch. Ground loop there.
jball85
  • Solder Ninja
  • James
« Reply #17 on: September 23, 2014, 07:23:53 PM »
This won't fix your problem, but you should invest in a Weller WLC 100 ($40). It should improve your soldering quality 10 fold.
nineknives
  • Diode Destroyer
« Reply #18 on: September 23, 2014, 08:29:19 PM »
We have lift off.  Thank you so much.  Your wisdom is invaluable and I appreciate it so much.  After it's all boxed up I'll post a video.  I believe the culprit was either a cold joint or the tiniest of solder bridges that I found.  I'm so excited.  Y'all helped me finish my first build!
  • Administrator
  • Brian
    • madbeanpedals
« Reply #19 on: September 23, 2014, 08:43:26 PM »
Thanks everyone for pitching in to solve the problem. I don;t say that enough.
nineknives
  • Diode Destroyer
« Reply #20 on: September 23, 2014, 09:41:24 PM »
As promised, the final build
I wish I could crank it right now but my roommate is gearing down for the night.  Thanks again, forum gurus.
« Last Edit: September 23, 2014, 09:44:28 PM by nineknives »
  • skilled electronics ninja master
  • Cody - Fresno CA USA
    • My Blog
« Reply #21 on: September 23, 2014, 11:02:21 PM »
Glad you got it going.. now get going on your next build :]
murdog47
« Reply #22 on: September 24, 2014, 03:34:56 AM »
Congrats!  :) :) :)
« Reply #23 on: September 24, 2014, 05:25:58 AM »
Did you end up replacing R1 again -OR- was the resistor in the second picture left on the PCB?
Congrats on getting it working  ;)
nineknives
  • Diode Destroyer
« Reply #24 on: September 24, 2014, 07:50:00 AM »
Lacky, I didn't have to replace anything on the board. I got rid of the ground loop and reflowed some solder in places.
« Last Edit: September 24, 2014, 01:25:42 PM by nineknives »
« Reply #25 on: September 24, 2014, 10:09:31 AM »
Lucky, I didn't have to replace anything on the board. I got rid of the ground loop and reflowed some solder in places.
Cool.
Still.. I wonder what that resistor value was  ???
