Potentiometer help
Started by Haberdasher, June 06, 2010, 12:46:39 AM
Haberdasher
Specifically how to get the same 16mm pots from mouser as the ones carried by smallbear?  I know they're 1/4" shaft, but mouser has so many different shaft lengths and different options I can't figure out which I should be putting in the cart.
Any help is welcome but if someone has a link that would be great!
thanks
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Haberdasher
Thanks man, that is allsome.
If they are out of a particular value can these be used in a pinch?
Haberdasher
A 12mm base would be nice but wouldn't a 15mm shaft length stick up higher than the .33 inch ones from smallbear?
Haberdasher
Hey madbean
If I get a 250K Linear pot and put a 170K resistor from lug 1 to lug 3 would that put me in the ballpark of 100kB?
Just making sure I'm doing the math right...
Haberdasher
Another pot question here...Do reverse pots work the same?
Example:  If I take a 250kC pot and solder a 5k1 resistor from lugs 1 to 3 does it yield me a 5kC?
thanks
