Current Lover Troubleshooting
Started by uber, October 26, 2014, 12:18:55 AM
R8... have you got a 5.6R resistor there instead of 5k6?
Quote from: Scruffie on November 08, 2014, 01:00:08 PM
good eyes. its looks like it to me, also.
uber
Oh man... I just found that my stash of supposed 5k6 resistors were mislabeled... Hopefully, this does the trick and saves me from problems on some other builds I have almost completed.
Regardless, thanks for all the help thus far and your patience.  Lesson learned.
Looks like I'm going to be headed to Fry's this afternoon.
itf?
I'm having issues with my Current Lover build but....I'll still chime in on a couple of things I notice. Is it me or is there jumper missing for your v3207 on the underside of the board?
Also, is the diode on the underside of the board D5? If so, shouldn't it be turned the other way around? Just out of curiosity, why is the diode stuck to the underside of the board like that?
I truly apologize if this just adds to the confusion.
danwelsh
Be careful how many times you solder and desolder those pads......with enough heat they will lift
