CE2 Clone (BYOC Analogue Chorus)
Started by raulduke, November 11, 2014, 06:14:21 PM
Not posted any builds for a while!
Here is my BYOC Analogue Chorus I built recently.
Lovely, lovely chorus; probably my favourite I have tried so far. Nice and 'warm' (for want of a better word).
It's been a while since I have built a BYOC kit and I forgot how much fun they are to put together.
I added a small mod; a switch to bypass the dry signal mix, giving an approximation of 'vibrato'.
The vibrato sounds pretty good considering the circuit and LFO are not optimised for it.
This is where the BYOC megachorus comes in (next on the list of 'must build' BYOC kits)...
Matt
Very nice. I like the "Ensemble" font. Don't know if I'm seeing this right, is the board angled to allow for the switch?
Matt
You've got a cool art deco thing going on there.  Outstanding graphics.
Looks superb all around and your deacl style is super! Dig it! 8)
Hogharry
Looks very nice indeed! I have to agree that it's a lovely sounding chorus.
...and then of course I've got this terrible pain in all the diodes down my left hand side...
pedalhealer
Very cool! Is the graphic is sticker?
www.pedalhealer.com
instagram: pedalhealer_dot_com
Yes mate its a polyester clear label.
Work really well for graphics (better than decals I have used)!
A few coats of enamel clear coat and the labels semi-meld to the enclosure.
Quote from: raulduke on November 13, 2014, 09:49:17 AM
link me to the supplier? Id like to try them. are they for lazer printers?
I used to use inkjet decals but they were not very robust.
https://www.gigaheartsfx.com
instagram @gigahearts_fx
Quote from: LaceSensor on November 13, 2014, 01:29:54 PM
Here you go:
http://www.aalabels.com/home/buy/2474
They are Matt (what I use at the moment), but they also have now have a gloss variant which might be worth try out (probably require less clear coat to get a nice flat finish)
They are a good company. Use them at work for all sorts of things (well... labels  ;D).
I too have used this method.
I use the #18665 label sheets from Avery.
It works really well for complex, big graphics where a waterslide decal might stretch and distort straight lines. You could realistically print out up to an 8.5" x 11" graphic that would be nearly impossible to do with a decal in one piece. I like to put a light coat of clear on after it dries to protect the ink while I'm putting it on the enclosure, then several coats of gloss, and it looks like paint.
Great-looking build!
Signatures are displayed at the bottom of each post or personal message. BBCode and smileys may be used in your signature.
Quote from: raulduke on November 13, 2014, 02:20:59 PM
Here you go:
quite pricey
avery do similar stuff for about £15 per 25 sheets
might investigate regardless
luks999
Here you go:
your pedals look fantastic with these!
are these polyester labels self adhesive ? do you use clear laquer to seal it?
Quote from: LaceSensor on November 13, 2014, 04:26:22 PM
Here you go:
quite pricey
Work well for me but suit yourself.
'your pedals look fantastic with these!
are these polyester labels self adhesive ? do you use clear laquer to seal it?'
Yes they are self adhesive and I use clear enamel lacquer.
You have to be very careful when applying the label; make sure you are straight because you will take paint of if you try and remove it after applying (I know this from experience  ;D)!
luks999
Thanks, raul ;)
i think i give these label a try :)
mweint
Hey, sorry to revisit this post after so long.  Just curious as to what you mean that the LFO and circuit are not optimized for vibrato.  I always thought chorus and vibrato were the same except for the addition of the dry signal in the mix and the vibrato effect being delayed a bit.  Would love to understand more about what optimizes a circuit for vibrato if you have any info on that!  Thanks so much.
