building a wah pedal?
Started by aran.e666, November 26, 2014, 10:11:28 PM
snz728
AFAIK the blue dots are where two links meet and are soldered to the same strip.  you only have to hook up two wires to the pot because it is acting like a variable resistor.  And wire the input, output, ground to the switch like madbean's general wiring diagram and 9v goes to the power plug or battery.
Stomptown
Quote from: snz728 on November 30, 2014, 04:57:58 PM
I'm glad someone verified that those were links! Lug 3 of the pot does need to be connected to the output according to  IvIark.mThis is a buffered wah so the mad bean diagram in not applicable unless he wants a true bypass pedal with a buffer.  Most propel remove the buffer if they go that route...
aran.e666
So I dont need the 3rd pin on the pot wired to the output on the switch? Thanks
Aran
Guitar is love, guitar is life.
aran.e666
Also im using a 6 pin spdt switch with the basic two top pins linked, middle lugs to output and last lugs to the mobo in/out. Thanks
Aran
aran.e666
I have finally finished the enclosure and also have ordered last parts. Thanks
Aran
snz728
Sorry, my bad about the 3rd lug of pot, etc. Havent built a wah in a while but I do recommend trying out different transistors with different hfes
aran.e666
Currently ive ordered the ones the layout shows but I will tty some time when I managed to put the whole build in a 1590b (lol) im building support bolts so it dosent lift up when I rock my foot forward and also im trying to get more 'action' on the pot by raising it (im using a lego gear and track). Any recommendations for transistors?  Thanks
Aran
aran.e666
Going off now so drop a reply and il check later :) cheers
Aran
aran.e666
Guys I really need help, ive fully assembled the wah and checked everything 20 times over. When I have the bypass on I hear the sound of the amp which is of course what bypassing is but as I switch to the wah effect, I hear no sound at all e.g when I have my killswitch on and it makes a tiny fuzz sound because of the amp. Any ideas? Ive even probed the switch and it works how it should :( . Thanks
Aran
Stomptown
Did you wire lug 3 to output jack AND the wire connected to board output? Are you wiring switch for true bypass? Pics?
aran.e666
Yeah im wiring a dpdt switch so I wire the circuit output wo lug 3 on the pot and chain that to the switch? Thanks
Aran
Stomptown
#41
Quote from: aran.e666 on December 04, 2014, 09:56:52 PM
Aran
Can you post a picture or a link to the wiring diagram you are using? I'm not sure I understand how you wired it up.
aran.e666
Ok so I found out that the reason it wasn't working was because I used multi core wire as a link so I used solid core and well it works but it isn't a wah pedal, its a volume pedal? Any idea? If uou need I can post pics of the board and il post the voltages of the trannies. ThAnks
Aran
Stomptown
Quote from: aran.e666 on December 06, 2014, 10:11:39 AM
Aran
I would post pics. It shouldn't my matter if you use solid or multi core
aran.e666
Ok so now I dont touch it for a day and now it dosent work again! It works as a volume pedal then later nothing!
