Current lover build issue
Started by hozy31, December 13, 2014, 04:31:37 PM
hozy31
Hi all,
New to forum so apologies if posting in wrong place.
I have an issue with my Current Lover build i get some noise coming through but before long R33 started to burn out. Any ideas why? Help would be much appreciated.
How are you supplying power/ what voltage? Which BBD chip did you use?
Yep. I clicked the, "continue without supporting us" link....
Try either increasing R33 to 47R or jumper it out altogether. That should solve the problem.
hozy31
I am using the MN3207 BBD chip and 9v 500mA power supply. I will have a go at jumpering out all together and see if that helps. Out of 13 builds this is the first problem i have encountered so overall feel quite happy. Thanks for response guys.
