Dirtbaby LED limiting
Started by claytushaywood, December 15, 2014, 06:47:30 AM
claytushaywood
I unfortunately missed out on the dirtbaby's short stock and I went ahead and tried the LED limiting mod on my deep blue delay... unfortunately I think its killing my pt2399's.
i am definitely going from pin 7 to pin4.
will this mod work on a deep blue clone?  or do i need to do something else to the circuit?
Matt
Connect it to pin 3. Pin 4 is not ground on the deep blue
Matt
sturgeo
Quote from: Matt on December 15, 2014, 12:07:26 PM
Whilst that is strictly true for the original, a lot of people connect 3&4 to GND as this fixes an issue with certain PT2399 chips.
Make sure you have the anode on pin 7, and make sure that your pin4 is actually connected to analog ground.
Muadzin
*Checks upon Dirtbaby pdf*
*realizes what he has missed*
claytushaywood
well i just quadrupled checked everything- got a new LED confirmed positive and negative legs.  confirmed pin 4 goes to ground.  put positive of the LED to pin 7 and negative to pin 4.  (both pin 3 and 4 connected to each other)
and i fried another pt2399... that's 4 good pt2399's gone :(
Quote from: claytushaywood on December 16, 2014, 03:46:37 AM
Chin up man, I get more than that bad in one tayda order :]
I don't understand how this is possible. I don't doubt it, but are you sure they are fried and not temporarily locked up somehow? Have you tried grounding all the pins and re-checking it? What are the exact voltage measurements you get on pins 7, 3 and 4?
claytushaywood
I have no idea about locking up pt2399s!  How exactly would I go about grounding each pin? Just individually connect.each pin to ground while powered on?
Matt
Quote from: sturgeo on December 15, 2014, 12:42:00 PM
I wasn't aware of this, thanks.
Matt
claytushaywood
Quote from: madbean on December 16, 2014, 09:37:03 AM
sorry I forgot to quote you on my last post-
how do i unlock the pt2399?  Do I just hook up the deep blue to my breadboard and power it then use a jumper cable to go to ground on the pins individually?
Quote from: claytushaywood on December 16, 2014, 09:06:40 PM
Often the chips will unlock after a day or two on their own. Your breadboard idea would be fine. I don't think you necessarily have to ground all the pins simultaneously, it's just to remove any stored capacitance. (Which drains over time, hence why I said that they usually unlock on their own after a day or two.)
I can't think of anything about the LED mod that would do what you've described. It simply conducts when the voltage on pin 7 rises to ~1.8V or higher, and it's been done in about 5 different designs now.
Quote from: midwayfair on December 16, 2014, 09:27:06 PM
Interesting.
Whenever I've had a PT lock up, I kill power to the whole circuit, wait 10-15 seconds, and power back up. Seems to solve the issue.
atreidesheir
Quote from: Muadzin on December 15, 2014, 02:24:29 PM
me toooooooo!
claytushaywood
Quote from: culturejam on December 17, 2014, 02:21:49 AM
Interesting.
thanks.  i promise you i am doing everything correctly.  i've tried it 4 times over about 3 days checking connections, checking LED's, having working pt2399's to begin with, checking voltages, everything.  its not exactly a difficult thing to do.
and now my pt2399s dont work.  ill check em tomorrow to see if theyve unlocked or if theyre donezo.
I believe I'm using those terribly dim LED's that tayda used to carry (maybe still does) and I used a 3mm diffused green LED.
