Author Topic: Pedalboard pics megathread  (Read 62634 times)
dawson
  • Stompbox Star
    • View Profile
Re: Pedalboard pics megathread
« Reply #150 on: March 22, 2020, 09:55:05 PM »
@Max, super cool build!  The aluminum looks awesome, and I can tell it's quite versatile and lightweight (until it's loaded with effects..)
Criticism is encouraged: constructive, or otherwise.
Max
  • Stompbox Star
    • View Profile
« Reply #151 on: March 23, 2020, 01:46:00 AM »
Thanks, yes, indeed it is quite light, but it's very solid, you can step on it. Well, at least I can, but I'm not exactly what you would call a big guy  ;D And with the velcro I can move it around without worrying about stuff flying off the board.
@Playpunk: your link is broken!
Aleph Null
  • Solder Ninja
    • View Profile
    • The Hard Problem
« Reply #152 on: March 27, 2020, 03:59:02 PM »
This is the first change to my main board in a while. I've crammed as much as I possibly can on a Pedaltrain Jr. Everything is powered by a One Spot CS7. The volume pedal is actually connected to a TRS jack send/return that's mounted through the frame of the board. This allows me to keep the pedal flat on the floor where it's easier to operate, but still have it sit after drives and before modulation and delay in the signal chain.
SirEgno
  • Transistor Tickler
    • View Profile
« Reply #153 on: April 01, 2020, 02:59:43 AM »
This is my last version.
the first is an empty box to power my bass guitar, so I don't need battery.
tuner into zvex machine clone, into ditto (I use it to test my effect), into an fet overdrive, into a mountainking megalith, into a bigmuff, into a CE-2, into an electric mistress, into a delay.
A lot of effect are missing, but at this moment I use only these.
It started in 2008 and changed about once a month.
Now I'm planning a modular cornish style pedalboard with programmable looper.
so I won't need enclosure, jacks and footswitches.
Marshall Arts
  • Electron Doctor
    • View Profile
« Reply #154 on: May 23, 2020, 09:38:16 AM »
Setting up a traditional blues / jazz board for a telecaster / matchless Spitfire Combination, that does not need a lot... Zendrive, King of Tone, Aion L5 (Clean Channel), Tap Tempo Tremolo, Alter Ego delay, Hall of Fame Reverb
« Last Edit: May 28, 2020, 01:59:55 PM by Marshall Arts »
Willybomb
  • Electron Doctor
  • Willy, not really a bomb.
    • View Profile
    • RockStarGuitar
« Reply #155 on: June 07, 2020, 03:57:41 AM »
This is where things stand at the moment.  Nothing in the loops, just using the drives in the MS-3 currently.  The only DIY pedals are Endgame, and the switcher on the bottom row... Still powered by a CIOKS AC10 mounted under the board.
« Last Edit: June 07, 2020, 07:02:12 PM by Willybomb »
  • Electron Doctor
    • View Profile
    • Project Website
« Reply #156 on: June 07, 2020, 08:03:02 AM »
Gotta admit, simple and clean.  I suspect the MS-3 has a tuner but once you go Polytune it's hard to use anything else.  I play a couple of different church campus' (well, at least back in the day when there were churches) and as much as I like my homemade stuff it's nice having a grab and go rig.  I use a Line6 M13 from time to time and although the distortions blow they're serviceable enough (and my amp sounds really good) that I could use it as a full time rig.  And that's super old school compared to the MS-3.
On lockdown outside of Chicago
Willybomb
  • Electron Doctor
    • View Profile
    • RockStarGuitar
« Reply #157 on: June 07, 2020, 06:51:29 PM »
The MS-3's tuner is pretty good, but I like the single strum "lets have a look" of the polytune.  The tech in the MS-3 is astounding compared to my old multis of the past (Korg A5, Vox Tonelab LE).
« Last Edit: June 07, 2020, 07:03:13 PM by Willybomb »
