How do YOU secure a battery holder?
Started by PhiloB, December 28, 2014, 06:08:51 PM
PhiloB
I've never put a battery in a pedal (1.5 years of building).  I have a few metal battery holders.  What's your favorite way to secure the clip to the enclosure?
jball85
I use decent (not crappy) hook and loop Velcro strip.
Also, a small rivet through the enclosure or 3m foam tape.
PhiloB
I have some industrial Velcro I may use.  Anyone ever use JB Weld?
mremic01
Quote from: PhiloB on December 28, 2014, 06:58:40 PM
JB Weld. Just a little bit of it will hold on of these nicely: http://www.taydaelectronics.com/9v-battery-holder-6.html
ChrisM
LizardKing
Quote from: mremic01 on December 28, 2014, 09:10:47 PM
Hmmmm, me likey dat dere holder.
MUST BUY!
NOM NOM NOM!
96ecss
JB Weld works great for me. I scratch up the bottom of the metal clip and the enclosure where the clip will go with coarse sandpaper. Then clean with a little isopropyl alcohol. I put a little piece of wood in the clip to simulate the 9V battery. I found that this makes a big difference in how well the JB Weld holds. I use the JB Weld quick set. It says it sets in 4 hours, but I let it set overnight.
This is the battery clip I use. http://smallbear-electronics.mybigcommerce.com/9-volt-battery-clip/
It has 2 small holes in the bottom. I put the JB Weld in the enclosure, then I push the clip down in it hard enough to make the JB come up through the 2 holes a little. I don't have any pictures to post, but I can take some and post if you want.
Hope this is helpful.
Dave
PhiloB
Thanks Dave, very helpful
Nice tip... thanks
I have never built a pedal with a bat but I am sure one day I will be asked to.
Quote from: selfdestroyer on December 29, 2014, 03:31:55 PM
Nice tip... thanks
For securing 9v batteries I use a heavy duty, adhesive backed velcro and a piece of bicycle inner tube as a battery sock, velcro on the sock and mating velcro on the enclosure, holding up well.
jball85
Quote from: davent on December 29, 2014, 04:53:29 PM
Nice tip... thanks
I like that, very cool. What's encasing, or going on with the battery clip wires in the pic?
PhiloB
That's slick.  What size inner tube?
Quote from: PhiloB on December 29, 2014, 06:17:41 PM
Specialized 700×28/38c, 27×1¼-1 3/8"
Quote from: jball85 on December 29, 2014, 06:14:31 PM
The battery clip's made from a dead Duracell battery, there's 1/8" Techflex around the leads, used it on the LED leads as well. http://www.parts-express.com/techflex-1-8-expandable-sleeving-25-ft-black--082-300
There's a guy in Germany who manufactures his own sleeving for pimping out PC's, much nicer colours and better looking going by the pictures.
Apparently they're taking a break at the momment, moving production, keep checking back on them, very cool stuff.
http://en.mdpc-x.com/mdpc-sleeve.htm
