transformer mistake and gift to me
Started by copachino, January 08, 2015, 02:10:33 PM
copachino
I have a friend who had a eggnater renegate amp bit another friend told him he have a tourmaster amp that he could chance it because ir had a bad transformer PT it waa common those transformer to blow. I told him if you want get the PT and i will replace ir for you , so he bought a mercury transformer and yesterday i start todo replace it when i turn ir on ir dindt work out.... So i meassure original PT and it das good so i look better and see that there was no voltage on the input and when i saw there wasnt a part on the plug.... So the whole amp only needed a fusile replace.... What a fool thing i just dindt check it before cos the last owner said he was sure ir was The PT...
The good its The amp has a new mercurio transformer and since today its my birthday my friend gave me the original 100w PT.... So its great todo source parts for an amp
Nice one!  8)
What voltages does the PT put out?
copachino
315 and 6.3 heaters Andrés 18v dont knoe what forma....has múltiple tapping for wattage selección was like 100w; 75w 50w and 20w
315-0-315 HT could be good for example for a Bassman type/JTM 45 solid state rectified amp (B+ will be higher through solid state than through tube rectification as you don't have a 5V rectifier tube tap anyway); you would have a B+ of about 430 V or so with solid state recto.
The 18V tap on transformer could be for some relay switching powersupply maybe and you could just ignore / tape that up unused.
Nice score.
