Author Topic: Volume level on Beast build  (Read 1001 times)
billstein
« on: January 13, 2015, 12:12:48 PM »
Hi all. I've just built the Beast by electricb. The Klon Maxon, OD-820 combination. On both sides I'm getting unity when I just barely turn the volume knob up. On a scale of 1-10 I'm probably reaching unity below 1.
Before I spend time trouble shooting I thought I'd ask to see if that is normal.
Thanks for your help,
Bill
« Last Edit: January 13, 2015, 12:15:21 PM by billstein »
  • skilled electronics ninja master
  • Cody - Fresno CA USA
    • My Blog
Re: Volume level on Beast build
« Reply #1 on: January 13, 2015, 12:31:16 PM »
I would check your values of R17, R43 & R44 and make sure they are correct. Its a start.
    • Project Website
« Reply #2 on: January 13, 2015, 02:08:33 PM »
Yeah, I'm hitting unity at about noon-ish depending on the gain setting.  Wrong taper pots maybe?
billstein
« Reply #3 on: January 13, 2015, 06:15:34 PM »
Just checked the resistors that Cody suggested and the pots. Everything is correct.
    • My Blog
« Reply #4 on: January 13, 2015, 07:26:19 PM »
Hmm, if you don't figure it out with your probe then take a look at this tread:
http://www.madbeanpedals.com/forum/index.php?topic=902.0
Post your pictures and any notes like subbed parts etc.. and maybe we can get you a bit further.
billstein
« Reply #5 on: January 13, 2015, 07:36:39 PM »
Thanks. I'll do a proper troubleshooting post. Because of time I was hoping for the easy and quick solution. :)
« Last Edit: January 13, 2015, 07:57:40 PM by billstein »
TGP39
  • Steven
« Reply #6 on: January 13, 2015, 10:07:36 PM »
Bill,  check your starting voltage. I had this happen to me and it turned out I was running 12.6 volts instead of 9.6 volts. The volume was unusually loud at small turns of the pot. Just something to check. Steve.
billstein
« Reply #7 on: January 13, 2015, 11:56:15 PM »
Thanks Steve. I'll check that tomorrow when I can get to it.
