Riggin' Up the Average Joe way! Input/Suggestions welcomed.
Started by GrindCustoms, January 23, 2015, 04:53:22 PM
micromegas
Quote from: Ettore_M on January 27, 2015, 03:35:08 PM
I own a Special 6 and it is a great little amp. And fully moddable. But being single-ended and a low-watter, I don't think it's a good solution for you. A bigger amp with higher headroom is what you need.  ;)
Also, I have played with a Transatlantic and it is awesome. Really! But a little pricey..
P.S. Yes guys! I'm back. After a lot of time. Almost a year.  :-\ But I always was around here reading your threads!
I'm happy I'm back! See you in my upcoming build reports.  ;)
Hector
Welcome back, Hector!
Software Developer @ bela.io
Ettore_M
Thanks a lot! Happy to be back!  ;D
Sorry for the thread derailing, Rej!  ;)
Hector
- Culturejam
People, people. This is turning into "list your favorite small/cheap amp."
The only reasonable way for Rej to get what he's asking is to pick the most popular budget amps. Anything more exotic than a Blues Jr. probably might as well be something Rej built himself.
Something like the Tiny Giant project works well into your average speaker cab....
playpunk
Quote from: midwayfair on January 27, 2015, 05:25:14 PM
Do you use your HRD when you test your designs?
"my legend grows" - playpunk
Quote from: playpunk on January 27, 2015, 08:14:40 PM
Yes, as I said, it's my bench amp. I don't crank the clean channel in the house, obviously, but I use it all the time. It can be too easy to make stuff sound good through my other amps. Once I've finished a design I take it to the other amps and make minor adjustments from there. The dirt channels let me test something through a dirty amp, it's completely clean when I need a clean amp, and it's got a full tone stack including mids and an effects loop.
playpunk
Quote from: midwayfair on January 27, 2015, 09:02:50 PM
I assume you set it flat? Just trying to get a sense of how you do things...
Quote from: playpunk on January 27, 2015, 09:10:18 PM
I usually put the controls at noon unless there's a specific reason I want to put the mids all the way up.
Ha, that's why my MG15 is my test amp. If something sounds okay through it (as opposed to crap), I know it'll be a right cracker through the Twin, or the JCM.
Plus I really don't care if a test pedal blows it up.
