Sparklehorn Build
Started by ratobasher, January 28, 2015, 02:55:36 AM
ratobasher
I've recently built two Sparklehorn projects. I used all 9mm metal pots. Wired it to use only one stomp switch. When a power supply, cable from guitar to pedal and pedal to amp are all connected, and pedal is in bypass mode, it makes a loud ground buzz sound. When I switch it effect mode I hear the delay and distortion and the buzz is grinding.  Has anyone had issues building this project.
ratobasher
Quote from: ratobasher on January 28, 2015, 02:55:36 AM
Has anyone built the sparklehorn and had issues? Are there any possible bugs with this board? Is this the wrong place to ask? Is there another Sparklehorn thread?
rullywowr
Welcome to the forum.
The best place to get help is in the "Tech Help" thread.  I am confident a mod will move this thread there soon.
Some detailed pictures of your build would be helpful as well as voltages on the IC's/Transistors.  Did you "rock it before you boxed it?"  (made sure it works on a test rig before putting it in an enclosure?
-Ben
ratobasher
Quote from: rullywowr on February 02, 2015, 06:46:01 PM
-Ben
Thanks for the advise. I did rock it before I boxed it. Still trouble shooting all the other points.
Is everything grounded properly? Are your jacks metal frame or plastic insulated. If the latter, you will need to ground the sleeves of both.
Barring that, a pic of your build will help.
ratobasher
Quote from: madbean on February 03, 2015, 08:03:59 AM
Odd thing is when i run a jumper from the cathode of D7 to the ground lug of the output jack, which is metal, i get the effect to to work.
