Author Topic: Current lover - Rate LED?  (Read 1405 times)
luks999
  • Solder Ninja
  • Gotta clone them all!
    • View Profile
    • Youtube Channel
« on: February 13, 2015, 04:46:21 AM »
is it possible in any way, to include a Rate LED for the current lover?
a LED that blinks with the current rate (speed)
the original didnt have one too, but im just curious
Scruffie
  • Electron Doctor
    • View Profile
Re: Current lover - Rate LED?
« Reply #1 on: February 13, 2015, 02:21:39 PM »
Yes it is!
Works at Lectric-FX
luks999
  • Solder Ninja
    • View Profile
    • Youtube Channel
« Reply #2 on: February 14, 2015, 03:10:35 AM »
but how?
didnt know much about the circuit...
  • Administrator
  • Electron Doctor
  • Brian
    • View Profile
    • madbeanpedals
« Reply #3 on: February 14, 2015, 08:33:21 AM »
Try this: solder a wire to pin14 of IC5. Solder the other end to a 1k resistor. Solder the resistor to the + side of you LED. Solder the - side of the LED to ground (or a wire that is soldered to ground).
I own madbeanpedals (duh). I am part owner of Function F(X).
Robusto
  • Diode Destroyer
    • View Profile
« Reply #4 on: December 10, 2019, 08:06:04 AM »
Not sure if i should make a new thread for this or bring this one back from the dead, so I'll start here. I just finished the Current Lover, and my rate LED only blinks when the pot is almost fully clockwise. From 0%-95%, it stays solid. Do I need to experiment with the value of R36 maybe? The clock trim? Has this issue ever been reported before?
