sunking with 8 position diode switch board
Started by cjkbug, June 07, 2011, 05:59:41 AM
cjkbug
here's a custom build I finished last month. it's a sunking with a daughter board with 8 different clipping options selectable with an 8 position dip switch done on perfboard. I've got a few oddball ge diodes. in60's,bat 41's, some nos turquoise leds. a pair of mosfets with a 1n34a in series. etc. all the options sound surprisingly different. the only option I don't like is no clippers.
It's housed in a 125bb. finished with interference paint that shifts color from green to purple. The pinup on the decal is a painting by Gil Elvegren. He's my favorite pinup artist. the girl resembles the owners wife who is of German decent like the girl in the painting. he had the pedal named after her. it is finished with several coats of clear lacquer, wet sanded to 2000 grit and buffed to a mirror shine.
sprayfe
petesz
cjkbug
I gotta see if I have some in focus gut shots.
night-B
The battery door is such a great idea! How did you managed to cut the hole for that? a dremel maybe? ???
brilliant. Both in function and appearance. Well done.
slimtriggers
Man, I love Gil Elvgren!  Great looking pedal 8)
jtn191
just killer. If you say switching diodes has that big of an effect, I'm building my next one like that!
bigmufffuzzwizz
Very nice job indeed! That LED is huge!  :o
The clipping option sounds like such a great addition. Did you see that one guy that mounted his DIP switch so it could be adjusted from the outside!
cjkbug
Quote from: bigmufffuzzwizz on June 08, 2011, 03:14:07 PM
I thought of doing that but I need to find a cleaner way than using a dremel. maybe drill the hole out and file to shape. how did he mount it? I'm not a fan of hot glue.
bigmufffuzzwizz
cjkbug
that's a neat way to go. epoxy makes repairs difficult. I'd install it on vero with the switch on 1 side and the diodes on the copper side with it screwed through the side wall of the enclosure. I started a sunking last night and I think I might try the Bean's switch option on 2 push pull pots.
Nice Job man, your wiring makes tasty viewing
