Zirconia Optical Compressor
Started by Haberdasher, March 18, 2015, 07:34:31 AM
Jebus
Quote from: Haberdasher link=topic=20398.msg199459#msg199459 date=1426807554
btw, only 2 pcb's left guys
/quote]
And now it's out of stock. Any idea when you're getting more?  :)
Haberdasher
#31
Quote from: Jebus on March 20, 2015, 12:24:34 AM
Quote from: Haberdasher on March 19, 2015, 04:25:54 PM
Yes I'm sorry Jebus, I am sold out for now.  I should have more in 2 or 3 weeks.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Jebus
Quote from: Haberdasher on March 20, 2015, 01:56:37 AM
No worries, I should have ordered it right away when I saw it. I'll keep an eye for it when you get more.  :)
tron
Is there any option/mods/changes to make a bass version of this?
Quote from: tron on March 25, 2015, 05:10:05 PM
Shouldn't be any need. The pedal's full range, the tilt eq can make it low-passed, and the ratio is pretty low so you shouldn't ned a blend. Have you heard the original? Is there anything about it you would want to change?
Quote from: midwayfair on March 25, 2015, 05:42:14 PM
The Tilt's mid point is not optimal for bass, however...
There was a separate guitar and bass version offered by Diamond, should be possible to build both on the same board and the mods to do so will be included in the build doc, externally all you should need is a charge pump.
tron
Yea I've never heard one, but since they made a bass version I thought (if easy enough) it would be cool to have a switchable version in the same pedal. Sounds good Scruffie!
Haberdasher
hi tron, the new build doc contains the bass components.  it's now on the lectric-fx website, or you can download it right here.
tron
TGP39
This is the layout I'd love to buy also. Great work...
Steve.
