Does anyone have the PDF SEA Urchin Deep Blue Delay
Started by wainer said, April 07, 2015, 12:47:49 AM
wainer said
Does anyone have the PDF SEA Urchin Deep Blue Delay ?
Or is the size of the board ?
I found a sign on the internet so that the measures do not have the PCB !
Tanks!!
wainer said
jimilee you have which are the board dimensions? Please!
Tanks
Justus
#4
Does this not help?   http://www.madbeanpedals.com/forum/index.php?topic=2832.0
Brian's gif image of the board layout is scaled properly at 600 pixels per inch.
(1215 px x 1251 px) / 600 ppi = (2.025" x 2.085")
wainer said
wainer said
Hello Guys!!
What's the correct voltage regulator stop this project? 78L05 or 7805 , because the layout seem to have a correct 78L05 ?
Luke51411
You can use either but they have opposite pinout. When I'm not sure I try to verify which pin on the layout has continuity to 9v and which has continuity to the power pin on the pt2399 and install the regulator according to the pinout given for the specific part I have.
wainer said
In the layout of the Sea Urchin and used the 7805 ? or 78L05 ? because I know I need to reverse the pinout
Easy way to find out is to look at the datasheet to find which pins are V in, V out, and ground, and then trace the copper connections on the PCB to find where the +9V pin is, the +5V pin going to the PT2399, and the ground pin. Then attach the regulator pins to the appropriate PCB copper :)
