"Black Hole" Shoot the Moon mini
Started by midwayfair, April 26, 2015, 09:39:17 PM
A customer up in Boston wanted a tremolo that could do stutter and softer wave forms and it needed to fit in a 1590A. He also wanted the rate knob as big as possible, so that meant I had to fiddle with the layout a bit to exclude the volume and make the waveform control a switch!
He plays bass clarinet, so I hope I get to hear something he creates using this!
I was so happy with the art that this one was a wrench to let go. I used "Midnight Rain" from PPP as the base powder coat -- it looks black but has a green sheen when the light hits it just right, and it also has some sparkle to it. I didn't want to use a flat black because I thought it would lessen the impact of the big black knob that makes up the black hole itself. Since every black hole needs something to feed on (or else you wouldn't be able to see it), I used the stuff sticking out of the pedals, and the LEDs obviously made the most sense. The colors start out "cold" (except for some silver around the edges to add some separation from the background) in actual heat terms and get brighter as you go toward the center of the accretion disc. There is also a white and silver background to make it look more like actual light. It's hard to photograph the metallic paints properly.
The Hawking radiation (that column shooting out from the center) was done with white and metallic blue.
I then used some paint thinner to smear the colors together and get some dissipation at the edges.
Favorite artwork yet Jon. Looks fantastic.
playpunk
Wowzers that rocks my world
"my legend grows" - playpunk
Compact awesomeness and super looks! 8)
Luke51411
Wow that might be your best art yet! And your art is all awesome! The layout and cram job is art all on it's own!
You make the 1590A in this build look spacious  :o
GrindCustoms
That's looking great!
With what did you end up doing for the wave form switch, as it usually just asks for a SPDT for full Sine-Triangle / Square wave?
Super painting Jon, came out great!
Quote from: GrindCustoms on April 26, 2015, 10:07:17 PM
It's a double throw. Middle lug is where wave 2 would go, outside lugs to the normal places.
I alter the resistor/LED network to soften the waveform for sine wave; the rate LED is in series with the vactrol and I use a 3K3 across the pair of LEDs instead of the 1K from the original. Seems a bit more balanced overall.
I also shoiuld have mentioned, I used Smallbear's 9203 photocell. Aside from being tiny, the dark resistance is massive so this does a really great stutter at high speeds. Not as good as a VTL5C1, but I couldn't fit one on the layout.
lrgaraujo
jprizz
Yes that would be a tough one to let go! Nice work Jon
