Pedalboard Build
Started by StevieM17, May 06, 2015, 12:38:43 AM
billstein
Excellent work. Love those dovetail joints.
StevieM17
Quote from: BrianS on May 06, 2015, 04:26:44 PM
Stevie that came out great. I like the dovetails. Did you make templates of your side boards? If not, before you separate yourself from the other boards you have get some mdf and make a pattern. If you ever want a bigger board just extend the length of it. That will save you a lot of time an effort. You have more woodworking skills than you led on too. Great job.
Brian
Thanks for the help Brian, I will definitely make some templates. I might try to go wider next time so that will help a lott
Coda-effects
Wow this is super cool!
I am trying to rewire my pedal board right now, I hope I will manage to make something as clean as you!
What is the black pedal on the right corner?
StevieM17
Quote from: Coda-effects on May 07, 2015, 08:17:32 AM
Thanks! and its a kingslayer 2 with my take on the em drive
Wow!  Top notch work right there!
Josh
Luke51411
That pedalboard looks great! Better than most commercial boards!
