Author Topic: Low profile jacks  (Read 1477 times)
billstein
  • Electron Doctor
    • View Profile
Low profile jacks
« on: May 08, 2015, 12:08:28 PM »
Hi all. I was just looking at the baby board guide that Brian put out. In it he uses low profile 1/4" jacks that came from Smallbear. I just checked and it doesn't seem like they still carry them. Do any of you have a source for these?
Stomptown
  • Electron Doctor
  • Jon
    • View Profile
Re: Low profile jacks
« Reply #1 on: May 08, 2015, 12:29:16 PM »
Here they are, but honestly I'm not a big fan of them myself.  That being said, they will give you the most wiggle room if that is what you are after:
http://smallbear-electronics.mybigcommerce.com/stereo-low-profile-pc-mount/
You could always use the lumberg/Kobiconn style open framed jacks for your build.  Paul has them is stock:
http://www.diyguitarpedals.com.au/shop/index.php?main_page=product_info&cPath=15&products_id=337
These wouls also work but would require careful drilling due to the size (I believe pickdropper typically uses this style)...
http://smallbear-electronics.mybigcommerce.com/1-4-in-mono-enclosed-111/
billstein
  • Electron Doctor
    • View Profile
« Reply #2 on: May 08, 2015, 12:42:48 PM »
Thanks Jon. I searched Smallbear and didn't see those. Maybe I'll throw a couple into the cart and see if I like them.
I do have a question though. It looks like those are plastic. Doesn't the jack have to ground to the enclosure?
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #3 on: May 08, 2015, 01:05:51 PM »
The diy guitar pedals link is chromosphere, he's good people.
  • Electron Doctor
  • Hamilton ON
    • View Profile
« Reply #4 on: May 08, 2015, 01:09:01 PM »
Hello Bill, The jacks don't "have  to" ground to the enclosure, but the enclosure needs to be grounded to the circuit so with plastic jacks you'd need to come up with another scheme to ground the enclosure to the circuit.. The plastic jacks' grounds and the enclosure ground would be seperately wired to circuit ground where with the metal jacks, they are hopefully solidly connected to the enclosure (starwasher) so the jack ground wire will also ground the enclosure.
With metal jacks you'll often see only one of the jacks ground connected to circuit ground relying on the enclosure to complete the ground connection to the other jack.
billstein
  • Electron Doctor
    • View Profile
« Reply #5 on: May 08, 2015, 01:23:27 PM »
That makes sense. Thanks for the info.
