Does this pedal exist (filter)
Started by LaceSensor, May 13, 2015, 02:02:53 AM
HI
Does anyone know of a self contained treadle/expression based pedal that instead of a wah sound gives a filter (low pass / band pass) sweep? I appreciate this can be done with MANY pedals using add-on expression pedals (classic example would be the moogerfooger low pass) however this requires lots of space.
The same is true of a number of other options.
The other consideration, outside a commercial offering, is to build a "static filter" into an expression pedal "shell" and solve the problem that way.
Any advice would be excellent.
Thanks
micromegas
digi2t's Tresonator. There was a build thread here, but now the first post is deleted....
Software Developer @ bela.io
micromegas
as a comercial option, you have this one:
http://www.sonuus.com/products_wahoo.html
but also takes a lot of space.
