Harbinger One - Deteriorated PCB
Started by pdhonte, May 15, 2015, 09:33:37 PM
pdhonte
Hello everyone,
I'm a beginner with a few vero builds, but not many pcbs. I had to change the 7815 a few times, thinking I was frying them and I wonder if I haven't managed to burn or melt the pcb now. I have taken voltage readings on the in and out pins, both from ground and +18 v, giving 0 each time.
See the pics below, it's ugly. What do you think? Is there a way to fix it? Or should I start over?
Pierre.
micromegas
if you are patient and skillful with a xacto knife, you can always remove some solder mask from the lines that went to those solder points and solder the component legs to them, I've done that with resistors a couple of times. The problem with this one is that those are power lines for the regulator, so you'd better solder them well.
However, the first thing I would do would be to clean the zone with a braid and then some isopropil alcohol to evaluate the damage.
Software Developer @ bela.io
pdhonte
Hello micromegas,
Thanks for the idea , I'll try that after the cleaning.
pdhonte
Tanks micromegas, it worked, I soldered directly the components together.
micromegas
Great! Enjoy your Harbinger.
Btw, did you use a solder sucker to remove the regulator? I always use a braid for that kind of things and have lifted a pad a couple of times. I am considering buying a Engineer SS-02 Solder sucker, Cody recommended it some time ago and I've read a lot of good reviews online.
Here is one of my "fixes" for your enjoyment :)
pdhonte
That's very clean! Much cleaner than what I did. I used a pump, but it was messy. I'm just not very skillful with at soldering. Why is it better to use braid there?
micromegas
#6
Quote from: pdhonte on May 18, 2015, 08:37:58 AM
It is not better, but sometimes the "sucking power" of the solder sucker is what lifts the pad if there's too much solder or if it's not completely melted, with the braid you have to be careful too but with some practice the results can be amazing.
playpunk
The ss2 is nice - I got one after using or trying to use the crappy blue one for a while. I still want a desolder station, but that will have to wait
"my legend grows" - playpunk
