Total Recall Gain 2 trim - volume always low at IC4, two separate builds
Started by lincolnic, February 05, 2016, 08:56:26 PM
danfrank
Maybe some at max delay time.
Keep all wiring away from the upper right corner of the PCB where the clock circuitry is, even if you have to reroute any wiring to the other side of the board.
atodovax
The thing is that the clock noise is even audible when i remove the jacks from the enclosure and put them far away... Any idea of a capacitor resistor swap that could lower theclock noise? I used the true bypass wiring and used shielded wires everywhere. Its my second build and the first one doesnt have this clock noise. I checked every single component and everything is fine. Should i reflow every solder joint?
